2x6 Joist Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2012, 02:53 PM   #1
2x6 joist span
I'm building a 20'x30' backyard entertainment room. It has 10' foot walls on 2 sides creating a L shape open room. I have 3 18" LVLs on one 30' side and 2 20' LVLs on the 20' side. The corner of where the LvLs meet is supported by a 5"x5" 3/8" thick square tube with 1'x1' plate on bottom on my concrete pad and also supporting the corner of the LVLs. I cut the 30' distance by also installing 2 18" LVL parallel to the 30'. I have installed 2x6 by 15' with hangers stretching to the the walls on 24" on center. Will that support 1/2" Sheetrock or wood paneling without bowing down?
marine02ss is offline   Reply With Quote
Old 05-04-2012, 03:57 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
regarding the 2x6 joists. a 15' foot span is excessive for 2x6's even just for drywall i would nail vertical 2x4's to the sides of the 2x6 tying them into the rafters to help reduce sag. if you do this though i would run a dryline across the underside of the 2x6's and use a feeler block to make sure the 2x6's are running flat.. any major variations in height in the 2x6's will telegraph through to the drywall
woodworkbykirk is offline   Reply With Quote
Old 05-04-2012, 07:08 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
I can't say that I understood much of your description of what you are building but here is the IRC joist span table for ceilings with no attic storage and 5 PSF for dead load and 10 PSF for live loading.
http://publicecodes.citation.com/ico...002_par023.htm
It might help you.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
16' joist span question. MikeVila Building & Construction 9 05-06-2012 08:40 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
20' span joist requirement johnny331 Building & Construction 6 09-19-2010 12:16 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 04:41 PM
