2x6 Insulation In 2x4 Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2009, 09:08 AM   #1
2x6 insulation in 2x4 framing
How could I use the 2x6 R-19 insulation in 2x4 wall framing. I am going to finish my basement and purchased some 2x6 insulation with the hope to insulate my basement ceiling as a soundproofing barrier. However after doing more research on the issue, I see people don't really think it is much help. So now I have roughly 1400 SF of 2x6 insulation and no really good place to utilize it, except if I use it when I insulate the 2x4 walls. Could I position the 2x4 walls out an inch or so from the cement walls to allow more space so the insulation fits snug? I am somewhat frugal, if you couldn't tell, and would like to use the insulation I already purchased. Thanks
Steve
Yorkspy is offline   Reply With Quote
Old 11-24-2009, 09:48 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,... It kinda defeats the purpose of 6" insulation to Pack it into 4"...
It's the loft of it that does the work, not so much the glass...
Old 11-24-2009, 10:51 AM   #3
Civil Engineer
Rewards Points: 4,782
The point about the loft is exactly correct, the glass has almost nothing to do with the insulating power other than to trap air. However, there is probably little difference in insulating value between compressed 6 inch thick fiberglass and uncompressed 4 inch fiberglass batts, so go ahead and use it, you already have it, and relax about the marginal loss in efficiency.
Old 11-24-2009, 11:01 AM   #4
Yeah, R19 will give you R13 in a 2x4 wall
Sometimes its hard to stuff into a 2x4 wall
and the fiberglass insulation should not be against the cement
Building the 2x4 wall out 6 1/2" to the face of the 2x will give you the clearance you need
Old 11-24-2009, 11:25 AM   #5
Kekeever
Kyle Keever's Avatar
Yes you can build the stud wall out to accommodate the 2x6 insulation. You may want to put some thoroseal or similar coating on the concrete for moisture protection. You will likely also need to install a vertical draft stop every 10 horizontal ft for fire code. This can be plywood or drywall. This is just to close the gap behind the stud wall to the concrete to prevent fire from migrating horizontally.
Kyle Keever is offline   Reply With Quote
Old 12-01-2009, 07:49 PM   #6
Thanks this is great help....I have a load of r19 that was given to me and I have 2x4 framing...glad to know I don't have to go out and buy r13....thank alot for the info
hebrewdiver is offline   Reply With Quote
Old 12-01-2009, 08:10 PM   #7
concretemasonry's Avatar
Rewards Points: 2,608
Those figures are provided by the pink panther and are probably for the lab tested ideal apllication for R-value of the compressed insulation and do not account for the heat loss through the studs, that can be significant, especially if you happen to use steel studs. (up to 40% loss for the wall compared to the R-value of the insulation R-value itself).
Keep in mind the results are "pink" for new. clean, dry insulation in short term lab tests and not real life. Fiberglass does not really absorb any real moisture, but it and an dust will hold it and only 1% moisture can dramatically reduce the insulation value of the insulation itself. Once fiberglass holds moisture (from condensation, leakage or whatever), the insulating value does not return. Since it has the moisture, the insulation is reduced and this can lead to more condensation/moisture since no wall have a real vapor barrier, but is only a vapor retarder.
You can get away with cramming the 6" batts into the 4"(-) cavity, but you will not get any better real effective insulation, but basements do not really need nearly as much wall insulation as above grade wall. Any soil or basement wall long-term temperature is rarely below 55F, while it may be -30F outside above grade. If you think about it, your floor probably has more area at a temperature about the same as the lower half of the uninsulated wall, so that can often be a bigger comfort problem.
Dick
concretemasonry is offline   Reply With Quote
Old 12-01-2009, 10:33 PM   #8
Registered User
Rewards Points: 5,516
Here is what the panther doesn't tell you: http://www.anchorinsulation.com/pdfs...insulation.pdf
And about the loss through the studs in the whole wall assembly: http://www.coloradoenergy.org/procor...f/r-values.htm
2x6 vs. 2x4 stud wall: http://www.advancedenergy.org/buildi...x4_or_2x6.html
You really should use some rigid foam board to stop any moisture from molding behind your batts: http://www.buildingscience.com/docum...gs?full_view=1
You may need a vapor barrier if in a cold climate.
Here is along the line Dick said:
http://www.quadlock.com/technical_li...Insulation.pdf
And don't forget the rim joists: http://www.rd.com/57548/article57548.html
Be safe, Gary
Old 12-02-2009, 05:24 PM   #9
Rewards Points: 410
I'd see if you could take the insulation back and apply the money to the methods that GBR has posted.
I'm using these methods on my basement project.
High Gear is offline   Reply With Quote
Old 12-02-2009, 07:24 PM   #10
PHB Construction LLC
Paulie's Avatar
Craigs List?
Paulie is offline   Reply With Quote
Old 12-09-2009, 12:21 PM   #11
Soundproofing Guy
Rewards Points: 158
Excellent thread! Previous comments are right on the money when describing the "loft" of the insulation. Too often compressed insulation in a cavity is equated to better sound isolation. This isn't the case.
Ted White is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Framing on Top of Insulation kothep Building & Construction 14 08-15-2009 02:48 PM
Finishing Attic - Framing (Raftters) & Insulation andgrim Building & Construction 3 05-01-2009 09:33 AM
Framing and Insulation billybarty Building & Construction 7 07-15-2008 06:18 AM
