2x6 Fascia - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 04:52 PM   #1
2x6 fascia
I'm preparing to repair some rotten fascia on my home. I've noticed the 2x6 fascia that is already there has a slot cut in the bottom for the soffit board to fit in. I've found 1x6 fascia boards everywhere. Can I buy 2x6 fascia, already slotted for fascia or do I buy 2x6 cedar and cut the slot on my table saw?
samuelplatter is offline   Reply With Quote
Old 09-05-2012, 05:28 PM   #2
Rewards Points: 14,312
Going to have to slot your own. A dado blade on a table saw or a router with a guide will do it.
Old 09-05-2012, 06:26 PM   #3
Thank you.
Old 09-05-2012, 08:23 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
is there a sub fascia behind the fascia? if so you could cut the 3/8" edge off of the soffit overhang and install new fascia tight to the sub fascia and even use 3/4" for the fascia.
hand drive is offline   Reply With Quote
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 12:21 AM
Fascia wood rot - how best to replace or repair? miamicuse Carpentry 4 01-11-2012 03:53 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
