2x6 Door Jams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 09:00 PM   #1
2x6 door Jams
I have two walls in my newly finshed basement that I had to use 2x6's to hide some support posts. I am wanting to put in pre-hung doors, but was wondering if they make 2x6 pre hung doors or will I have to hang the door from scratch? Any info on both ways would be helpful.
cambishop is offline   Reply With Quote
Old 01-10-2010, 09:13 PM   #2
They do make them, big box usually a special order
I used a 2x4 on my front entrance & actually have maybe 135 degree opening
Since there will be a bench on the porch I didn't need it to open wider
Old 01-10-2010, 10:00 PM   #3
jlhaslip's Avatar
Rewards Points: 2,184
There are also Jamb extensions that are available to widen the 2 x 4 jambs.
jlhaslip is online now   Reply With Quote
Old 01-10-2010, 11:18 PM   #4
Rewards Points: 150
I would look at the 2 x 6 door.
This is just a thought and not something I have done personally or even seen in person but if the r.o is wide enough to start can you put another 2 x 4 centered in the 2 x 6 jamb and make your new r.o. with the 2 x 4
canyonbc is offline   Reply With Quote
Old 01-11-2010, 12:09 AM   #5
jlhaslip's Avatar
might affect the door swing and it would be more difficult to trim out.
Old 01-11-2010, 12:12 AM   #6
Rewards Points: 150
something i did not think about.
How do the trim that make a 2 x 4 door fit into a 2 x 6 wall
Old 01-11-2010, 07:47 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Assuming an in-swing door, install the door flush with the inside finish material (drywall). Then install extension jambs on the exterior jamb to bring it out even with the exterior sheathing. Easy to do and cheaper than special ordering a door with 6 inch jambs.
Re-read your post and realized you are taking interior doors. The same idea as above, install flush with the finish on the in-swing side of the door and install the extension jambs on the other side of the wall.
Coastal South Carolina
Old 01-11-2010, 06:01 PM   #8
Drywall contractor
Rewards Points: 1,070
Some of the Home Depot stores (here locally) actually stock the 6-1/2" jamb pre-hung doors. They can all "special order", but that can be a lot more expensive if your local store doesn't carry them. I'd try a regular lumber yard if you have one in your area before ordering from the "big box" store. They're often much cheaper, and the "wait time" to get the product is probably half...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-11-2010, 06:06 PM   #9
you can also get 6-9/16" jamb sets or make your own using router to ease the edge and groove the back for stability
Old 01-11-2010, 06:57 PM   #10
you wanna save money and have some fun? Make your own pre hung door with some 1X8"s, a cheap hinge set, door stops, yada yada yada
really easy to do. If you want to try it, let me know and I'll help you through it (if you need help).
II Weeks is offline   Reply With Quote
Old 01-11-2010, 11:19 PM   #11
firehawkmph's Avatar
Rewards Points: 1,884
Cam,
The jamb extensions are very simple. Take some 3/4" thick stock and rip it on a table saw to 2" if you are using 1/2" drywall on both sides of the wall. If you have access to a pocket screw jig, you can attach the extensions in just a few minutes. If not, get some trim head screws and predrill the extensions and screw them together with a little titebond glue.
Inexpensive and easy.
Mike Hawkins
firehawkmph is offline   Reply With Quote
