2x4 Sliding Door Over 2x6 Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 03:10 PM   #1
2x4 sliding door over 2x6 walls
Hi Guys,
I am in the process of adding 1 1/2" rigid foam insulation to my exterior walls, and replace all windows and doors.
One of the doors is a sliding door in the back yard, the rough opening is about 74X82, so I guess I can make it 72X80 by adding a couple of studs. My existing wall construction is 2X4, so adding 1.5" rigid foam will make the wall about 2x6.
I went to Home Depot and Rona, and none of them seem have 2x6 sliding patio doors in stock, and special ordering one will cost about 1500 dollars vs 570 for the 2x4 door.
I am wondering if I can buy a 2x4 sliding door and install it over the now "2x6" wall? I probably need to add some interior trims, to build it out to the interior wall surface.
What other options do I have?
Thanks!
Hexar is offline   Reply With Quote
Old 04-13-2010, 06:03 PM   #2
kwikfishron's Avatar
Rewards Points: 1,006
Originally Posted by Hexar View Post
Hi Guys,
Thanks!
You answered your own question.
kwikfishron is online now   Reply With Quote
Old 04-13-2010, 09:15 PM   #3
jlhaslip's Avatar
Rewards Points: 2,882
they are called 'jamb extensions'
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-14-2010, 12:49 PM   #4
Rewards Points: 150
Yup answered it himself. Make some jamb extensions, glue and pocket screw them to your existing jamb, paint / poly, done.
slickgt1 is offline   Reply With Quote
Old 04-19-2010, 04:03 PM   #5
cool. Thanks guys! I can now buy a 2x4 sliding door and save some dollars!
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
