2X4 Skylight Framing Detail Drawings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 06:09 PM   #1
2X4 Skylight Framing detail drawings
Can anyone supply the framing detail drawings for 2X4 skylight installation?
msilver is offline   Reply With Quote
Old 04-25-2012, 07:52 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
http://www.thanatopsic.org/hendrik/images/315.jpg
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
AndyGump (04-26-2012)
Old 04-25-2012, 08:00 PM   #3
Rewards Points: 13,458
This may work out better.
http://www.veluxusa.com/professional...tallation_help
Old 04-25-2012, 08:09 PM   #4
Originally Posted by joecaption View Post
Not sure what you were linking to in your reply, but the OP is asking for a detailed drawing,.......not "installation instructions".
IMHO: Based on the specific wording of the OP's question, I would assume that this is likely for a Building Permit Application (actual structural alteration plan to submit for approval).
- Build Well -
Old 04-25-2012, 08:35 PM   #5
Rewards Points: 150
Is this what you mean?
If you cut a rafter double up the cross support.
If the width is less than 22.5 inches, it can drop between 24 in oc rafters. You should place it so you don't have to cut any rafters. In this case you only need single cross supports.
Not sure why the picture is not showing up. click the X to see it.
goosebarry is offline   Reply With Quote
Old 04-25-2012, 09:33 PM   #6
U should never touch the truss' because they r structural u need to go in between them which will be 22 1/2" by watever length u want but for problem free work I would go quarter inch smaller so it's an easy fit n it won't matter cuz u will still have to waterproof it (silicon)
ninjahero is offline   Reply With Quote
Old 04-26-2012, 12:46 PM   #7
Rewards Points: 150
Correct and correct.
Never cut trusses unless you have done the engineering to figure the effect on loads.
I probably should have said that many so called 2 ft wide sky lights are designed for a 22.5 in rough opening so thay fit between rafters 24 in oc.
BTW, the diagram is 16 in oc.
Question to the OP, was this what you wanted or were you talking about the box between the roof and ceiling?
Old 04-26-2012, 01:27 PM   #8
Rewards Points: 502
Has the OP stated whether it is a rooflight to go between trusses or just between rafters in a vaulted ceiling? The details will obviously differ.
tony.g is offline   Reply With Quote
Old 04-26-2012, 08:51 PM   #9
U should never cut them period regardless if ppl say u can, if someone tells u that u can just laugh at them and tell them that they r stupid and don't no wat the hell they r talkin bout
Old 04-27-2012, 04:49 AM   #10
Rewards Points: 502
We still don't know whether the OP is talking about trusses or not, so none of this helps him.
Old 04-27-2012, 05:18 AM   #11
Framing Contractor
U should never touch the truss' because they r structural u need to go in between them which will be 22 1/2" )
Why are you saying trusses when no one mentioned trusses?
Joe Carola
Joe Carola is offline   Reply With Quote
Framing in Velux Skylight Scott531 Building & Construction 4 08-19-2011 04:32 PM
Help with skylight framing cumak Building & Construction 16 04-24-2011 11:39 PM
Skylight framing cumak Building & Construction 3 10-19-2010 01:29 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing detail question bernie Building & Construction 7 11-16-2007 08:20 PM
