2x4 Roof Structure For Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 08:20 AM   #1
2x4 roof structure for garage
The space above the garage is a 2x4 structure. I want to use this space for storage. Will it hold or do I need to reinforce
murpp7 is offline   Reply With Quote
Old 11-04-2012, 08:24 AM   #2
Rewards Points: 236
if its trusses, you can . but if its stick build, you will need reenforcement.
got any pics ?
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
murpp7 (11-04-2012)
Old 11-04-2012, 08:24 AM   #3
Civil Engineer
Rewards Points: 4,856
This is a pretty common question on this forum. I suggest you search previous threads for a full discussion on load capacity of floors. Whether the 2x4's will hold depends on the span of the joists, the species of wood, the spacing of the joists, and the load per square foot of what you want to put up there.
Old 11-04-2012, 08:25 AM   #4
Rewards Points: 14,014
Got any pictures.
Going to need far more info, your there were not.
Unless you plan on storing styrafoam, 2 X 4's are not going to hold much.
murpp7 (11-04-2012)
Old 11-04-2012, 08:41 AM   #5
The span of the joists are about 20'. The material is 2x4 yellow pine on 24" center. Plan on storing just misc household items (xmas stuff, coolers, etc.) nothing heavier than I can pick up.
Old 11-04-2012, 08:45 AM   #6
2X4's are going to sag, there in place to keep the rafters from spreading.
For that span you would need at least 2 X 8's.
murpp7 (11-04-2012)
Old 11-04-2012, 09:25 AM   #7
Rewards Points: 236
yeah. they are probably sagging already. i have a 2 2x6's in my new garage that span 21', and they sag. if the rafters are in good shape, you "may" be able to put some (can't think of a good word for them) braces that go from the joists to the rafters to help hold some weight. my new garage has them, and they work, to a limit.
Old 11-04-2012, 11:03 AM   #8
Civil Engineer
Assuming an allowable stress of 1200 psi (reasonable for yellow pine), and assuming the true dimensions of your lumber is 1.5 inches wide by 3.5 inches deep, and based on your description of 20 foot spans, 24 inches on center, your 2x4 joists can hold approximately 3 pounds per square foot based on bending capacity. This means you cannot store anything up there safely, in fact you should not even walk on the joists. As mentioned previously, those 2x4's are not there to support a floor, they are only there to prevent wall spreading, for which they are fine.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
murpp7 (11-05-2012)
Covered patio structure pitched roof WHBIII Building & Construction 8 06-01-2011 04:52 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
