2x4 Imbedded In My Basement Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-20-2012, 04:01 PM   #1
2x4 imbedded in my basement slab
I have an older home in which the basement was added after the house was built. In one of the rooms, approximately 6 inches away from the foundation wall is what looks like a 2x4 or a 2x6 imbedded in the slab. I'm thinking it might be leftover from the slab but I'm not sure. In either case, it's completely rotted and breaks apart in pieces. I'm planning on ripping it out and pouring cement in to fill the void, but was wondering if this was the best idea or if anyone could suggest something else. It seems I have some water coming up through the 2x4. Not much but just enough to cause the cement around it to be damp...
Thanks!
alexlacelle is offline   Reply With Quote
Old 09-20-2012, 06:29 PM   #2
Rewards Points: 13,274
That's a termite magnet.
Drill it, chisle it, whatever to remove it, suck out the chips with a shop vac and fill it with Hydrolic cement not concrete.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
garlicbreath (09-20-2012), mae-ling (09-21-2012), oh'mike (09-20-2012)
Old 09-20-2012, 06:58 PM   #3
DIY staff
Rewards Points: 7,174
Hydrolic cement expands a bit as it cures,giving you a better water seal than regular concrete--
Old 09-20-2012, 09:27 PM   #4
Rewards Points: 150
3rd that!
oodssoo is offline   Reply With Quote
Old 09-20-2012, 09:47 PM   #5
That will be the plan! Thanks for the quick replies!
Want to Install Ceramic/Porcelain and Insulate Basement Slab illusion8055 Building & Construction 2 08-15-2012 02:19 PM
Ditra over basement slab? Trustmemalawyer Flooring 1 08-12-2011 06:58 PM
2X4 Framing on sloped basement slab chobio Building & Construction 2 07-02-2011 09:11 AM
retrofit slab insulation in finished basement... worth the trouble? gbwillner Building & Construction 20 11-17-2010 01:05 AM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
