2X4 Framing On Sloped Basement Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 04:44 PM   #1
Question
2X4 Framing on sloped basement slab
I have just started framing for basement wall.
I built section (top plate+ studs+ bottom plate) on the floor and raised the section up into the space.
It did fit into the space, but the floor is sloped, so one side of bottom plate sits on the slab but opposite side is 1"1/2 floating from the slab.
(tilting side to side. not back and forth)
Is this OK with adding shims or spacer? I am going to use Ramset(gunpowder nailer) to secure the bottom plate to the floor.
Or, should I cut each studs in different length so the bottom plate goes along with the slope?
I appreciate your advise.
chobio is offline   Reply With Quote
Old 07-01-2011, 04:51 PM   #2
AGWhitehouse's Avatar
Not ideal, but not the end of the world. Since the wall is load bearing you can get away with it. I would keep the bottom plate flush with the concrete so you can shoot it in good with the power shot.
With the top plate, I would take another 2x4 and run in either on a table saw or with you skillsaw to make a wedge to fit your gap. Attach the wedge to the top plate and then attach the top plates to the joist. Once the sheetrock is on, you'll never know.
AGWhitehouse is offline   Reply With Quote
Old 07-02-2011, 08:11 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Classic mistake.
Attach top plate
Plumb down and attach bottom plate
Cut studs to fit. Toenail 2-8d on one side and one on the other.
Use the studs you allready cut for blocking, jacks etc.
12penny is offline   Reply With Quote
retrofit slab insulation in finished basement... worth the trouble? gbwillner Building & Construction 20 11-17-2010 12:05 AM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 12:06 AM
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 11:28 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Metal Stud Framing in Basement toolman327 Building & Construction 2 01-01-2009 06:52 PM
