-   -   2x4 Exterior Wall Insulation (http://www.diychatroom.com/f19/2x4-exterior-wall-insulation-40586/)
stubits 03-18-2009 07:45 AM
I planning an addition to my house and am starting to think about insulation. Based on my reading of the local code, the exterior walls need to be insulated at r-18 value. As this is an addition and we have relatively limited space, I had been planning on building it out of 2x4, but using batt insulation, I believe I would be limited to r-15, no? So, any thoughts on what I can do?
So far as I can tell, my options are:
1) Frame using 2x6 - This is not a preferred option because space is so limited. Even 2" will make a difference.
2) Install r-15 batt insulation in the stud cavity and a layer of r-5 foam board insulation on the exterior, for an r-value of 20
3) Install spray foam insulation in the stud cavity, 3" thick for an r-value of 21.
4) I have read of some people doing a 1" spray of foam insulation in the stud cavity and then installing batt insulation on top of that. Any experience with this method? Would you have to compress the batt insulation?
Any other thoughts? What's your preference?
Thanks!
Bob Mariani 03-18-2009 08:58 AM
2 X 6 walls or spray with closed-cell is the only way to go. 2 X 4 with batt insulation is R-13 only. Using a 1" spray and then R-13 will still not give you what the code requires. And code requirements are minimums. More is better. 2 X 6 walls are the way to go.
stubits 03-18-2009 07:10 PM
Thanks Bob.
For what it's worth, Owens Corning, and a couple of other companies, now have high density fiberglass batt insulation that allows for r-15 in a 2x4 wall and even r-21 in a 2x6.
That said, I am seriously considering how to make the 2x6 walls work. The room is just very narrow and I am trying to loose as little space as possible.
Any other suggestions?
Thanks!
Bob Mariani 03-19-2009 05:07 AM
In my area we need R-19 so this is why I say 2 X 6 walls or spray ins...
stubits 03-19-2009 07:03 AM
2x6 is definitely the way to go, thanks for the advice. And I agree the more insulation the better.
