Old 03-05-2012, 01:34 PM   #1
2x4 ceiling joists?
This is my first post so go easy on me.
I would like to know if I can use 2x4's for ceiling joists for a 10' span instead of 2x6's ? I have a garage with a open ceiling height of 16' and I'm building an office 10' by 10' with a ceiling height of 10 feet. The space on top of the ceiling will be used for storage. So what I'm really asking is this. Is it legal and safe to use 2x4's for this ceiling? I will be using drywall on the ceiling.
Thanks.
Pierrel'Ami is offline   Reply With Quote
Old 03-05-2012, 01:38 PM   #2
2x4 ceiling joists?
Not even close.
http://www.awc.org/calculators/span/...rcalcstyle.asp
Old 03-05-2012, 02:13 PM   #3
2x4 ceiling joists?
To reinforce what Joe said, set a 2x4x10' on a block on each end and walk on it. I think you'll find it a little spooky. You could maybe squeek by w/ them, but the cost savings is trivial, if that is the issue.
Old 03-05-2012, 02:20 PM   #4
2x4 ceiling joists?
Even with no top loading like you plan to do it will not work. sagging screw pops, cracked joints in the drywall.
Your going to need 2 X 10's 16" on center.
Just cut the tops of the joist at the same angle as the roof pitch.
Old 03-05-2012, 05:47 PM   #5
Moderator
2x4 ceiling joists?
Only if you used Southern-pine, SS grade or #2 at 12" o.c.: TABLE R802.4(2) CEILING JOIST SPANS FOR COMMON LUMBER SPECIES (Uninhabitable attics with limited storage, live load = 20 psf, L// = 240)
Here, if under this code: http://publicecodes.citation.com/ico...002_par023.htm
Gary
P.S. Welcome to the forums!
Clothes taking longer to dry?
Old 03-05-2012, 06:11 PM   #6
It was a dark and stormy
Yoyizit's Avatar
2x4 ceiling joists?
It also depends on your O.C. spacing.
Can you take some load off your office ceiling by running struts to your garage ceiling?
Old 03-05-2012, 08:21 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
2x4 ceiling joists?
Thanks.
For "Storage Use", full span of 10' and un-supported = No
Some information:
http://www.askthebuilder.com/B124_Fl...ts_Table.shtml
- Build Well -
Old 03-05-2012, 08:39 PM   #8
Wire Chewer
Red Squirrel's Avatar
2x4 ceiling joists?
I would go at least 2x6. But if you really must use 2x4 because of some clearance issue or something, set them on every 8" instead of 16". I don't know about the legality of that though.
Red Squirrel is online now   Reply With Quote
Old 03-06-2012, 12:34 AM   #9
Just a DIY guy
2x4 ceiling joists?
I'm with you. Even 2x6 at 10 feet is going to flex a bit.
And finding the right species of lumber in the right grade as GBR suggests might work seems like tempting fate. Too close to the limits.
The lumber costs are pretty minimal to upgrade to a 2x6, in the overall cost of building out an office.
M3 Pete is offline   Reply With Quote
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 08:52 PM
Sagging Ceiling Joists Steve Burke Carpentry 12 12-13-2009 06:18 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 11:14 AM
locating ceiling joists magal2005 General Discussion 2 12-12-2007 11:17 AM
