2x3 Wall Frame? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 12:11 AM   #1
2x3 wall frame?
Hey guys I was considering framing out a non load bearing basement wall with 2x3s. Is this ok? Anyone have experience with this?
Aloha1 is offline   Reply With Quote
Old 09-22-2011, 06:28 AM   #2
DIY staff
Rewards Points: 7,174
Yes---Makes for a weak wall that is hard to get electrical into--and usually takes more time to build as the 2x3s are often cut from junk wood.
Doors are designed for a 2x4 wall so you will need to custom make door casings.
Why ??
Old 09-22-2011, 06:38 AM   #3
The only reason I would consider 2x3 walls is to save an inch of space. There is no savings in using 2x3 over 2x4.
Keep in mind, any wood touching concrete should be pressure treated.
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Frame Basement Wall OhioDon Building & Construction 4 07-08-2010 12:09 PM
Joining timber frame to brick wall deyveed Building & Construction 2 10-27-2009 08:02 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
