#1 |
2x3 load bearing wall
I need to change 8 ft of a load bearing wall to a 2x3 wall to gain space needed to fit a washer dryer. There is an existing 36 inch header for a passageway. How do I create a header for the 2x3 wall. I will be doubling up each 2x3
#2 |
DIY or die !
how is 1 inch more of depth going to make enough more space for a washer dryer? what is there now ? You could always just remove the wall and install a beam.
#3 |
Can you post pics and diagrams and perhaps we could help better?
#4 |
Do the appliances go that high where the header will be? Header can not be changed by yourself. Even if you could with engineer's ok, make sure joists above are sitting on the header at least 1 1/2".
#5 | |
2x3 load bearing wallQuote:
#6 |
Can you use 2x3 only for the area beside the machines then leave the rest as 2x4?
Doubled 2x3 is a good idea for the studs. How high of a header? |
#7 |
Average Joe/ex-Navy IC3
It would be easier to just move one wall back, then tear the old wall down, vs. going through trying to build mobile home framing to replace the other. Sounds like either poor planning back in the day, or the space was intended for smaller sized machines than what you have in there now.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#8 |
Neither wall can be moved. Indeed the room was built in1953 for smaller machines
#9 |
Never say never. Post drawings and pictures. Floorplan helps, along with knowing if you are on a Slab, Crawlspace, or Basement.
#10 |
i have no idea if either of these suggestions is necessary, but reducing a 2x4 to 2x3 has a SERIOUS effect on the strength of the stud. for ex, i was given these numbers by a guy who teaches building science at a small university: "A single SPF#2 9' 2x4 that's restrained laterally by sheathing or blocking can support 1820 lbs and a similar 2x6 can support 7061 lbs without buckling." thus, i'd be real careful replacing a 2x4 w/a 2x3 if the wall is load bearing. i THINK, and this is only a "think," you will have a stronger member if you nail your 2x3's into L's; better yet, U's. i have no idea if either is necessary, but reducing a 2x4 to 2x3 has SERIOUS consequences for the strength of the stud. i don't know the exact exponent, but the "strength" of a stud, be that bending or holding load w/ out failing, is not linear.
| The Following User Says Thank You to jklingel For This Useful Post: | woodworkbykirk (01-01-2013) |
| Display Modes | |
| Do you think this wall is load bearing? | rchickering | Remodeling | 17 | 11-21-2011 06:35 PM |
| Looking into removing a load bearing wall | IRuehl | Remodeling | 5 | 07-02-2011 04:39 PM |
| Is this wall load bearing - pictures attached | jen5219 | Building & Construction | 16 | 08-01-2010 01:17 PM |
| Load Bearing Wall Issue? | iggy913 | Building & Construction | 1 | 07-28-2010 07:45 PM |
| Removing a 4 foot opening in a load bearing wall (for fish tank) | ~callie~ | Building & Construction | 1 | 07-15-2009 06:10 PM |
