2nd Floor Subfloor Replacement, HELP! - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-19-2008, 07:23 AM   #31
Work in progress.
redline is offline   Reply With Quote
Old 02-19-2008, 08:10 AM   #32
Clueless! :)
leahjane10's Avatar
Latest pics
Redline,
Here are the pictures that I took last night. The flash was really bright, but rather dark without it. (Keep in mind that I am still going to remove the floor that is still where the bathtub was.) Let me know what you think!
Leah
2nd Floor Subfloor Replacement, HELP!-pic1_smaller.jpg   2nd Floor Subfloor Replacement, HELP!-pic2-1-_smaller.jpg   2nd Floor Subfloor Replacement, HELP!-pic3-no-flash_smaller.jpg   2nd Floor Subfloor Replacement, HELP!-pic4-1-_smaller.jpg   2nd Floor Subfloor Replacement, HELP!-pic5_smaller.jpg
leahjane10 is offline   Reply With Quote
Old 02-19-2008, 11:26 AM   #33
(in the last photo)
There is the stud that is in between the toilet water supply and then it runs along to the shower, how far does the plywood with the curved cut extend out from the joist ?
It appears to be around an 1"?
You may be able to nail/screw (2) cut down 2x 6's parallel to the joist that is under the wall in order to get a nailing surface for your sub floor.
It all depends on if it will extend beyond the old floor.
Old 02-19-2008, 11:29 AM   #34
Originally Posted by leahjane10 View Post
.. (Keep in mind that I am still going to remove the floor that is still where the bathtub was.) Leah
If the plywood is not damaged where the tub is then you could leave it but that is up to you.
You may need to leave a small section open when you make the connects below the tub and then install that section last.
