I have 5W x 6L closet that I am going to make into a laundry. I can get drain and water their easily.
What I am worried about is the vibrations of a front loader hurting the structure of my house or cause damage to rooms below. There is 3/4 plywood as the subfloor.
Would anti vibration pads or feet be sufficient or do I need to add another layer of plywood plus pads?
I will be making the floor Tile and have drain in the floor incase of water leaking or machine failure.
How do I keep the high frequency vibrations from hurting the rest of the house?
my front loader that I have not doesn't walk or move when it runs. I had it on a first floor before we moved at never had problems. The first floor had a tile floor with 3/4 plywood subfloor. No joist reenforcement.
Thanks.
Thanks.
