2nd Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 12:19 AM   #1
2nd floor joist
I am building an office addition in a warehouse with a loft above the office. I installed 2x6x12 joist. When I walked on them to test the strength, they were bouncy. What can I do to make it more sturdy?
rocke is offline   Reply With Quote
Old 09-14-2010, 01:03 AM   #2
Was there any calculations done when you chose 2x6? Did you check with span tables?
IMO, you really should use at least 2x8.
Now that its up though, I'm not totally sure what you can do. Maybe sister in some addition joists. I'll let someone else chime in on that.
acerunner is offline   Reply With Quote
Old 09-14-2010, 02:20 AM   #3
liscenced electrician
Rewards Points: 538
i agree with the post above. I probably would have used 2x10's for that. Your only real options are
add more joists
put a beam in the middle to support the middle
live with it
rip it out and use 2x8 or 2x10's
jimmy21 is offline   Reply With Quote
Old 09-14-2010, 03:00 AM   #4
Rewards Points: 1,092
If tearing it all out is not your game, maybe you can add height to the existing joists by putting a 2x4 under them (vertically, of course) and glue and screw plywood to both members. Use the longest plywood you can get (9'?) and put the extra boards/plywood on the center of the 12' span. Either that, or put plywood and 2x4s full length on both sides, staggering joints on opposites sides.
Old 09-14-2010, 03:01 AM   #5
" Euro " electrician
frenchelectrican's Avatar
2X6 by 12' is too small a joist to use.
You will have to sister it up or rip the whole thing out and use 2X8 or 2X10 depending on your code and load caluatuations is.
Or the wooden I-joist will work ok if the code do allow it.
Merci.
Marc
Old 09-14-2010, 04:09 AM   #6
Framing Contractor
Ask the architect who drew the plans what to do. It's an office, you do have approved plans, right?
Joe Carola
Joe Carola is offline   Reply With Quote
