2nd Doorway To Furnace Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 09:23 PM   #1
GBunny
Rewards Points: 71
2nd Doorway to furnace room
The previous owner removed a stud on each side of the stairs to make a doorway under the stairs to go into the furnace room.
I realize this is a load bearing wall and needs to be fixed. I have two ideas:
1. Create a proper doorway with extra studs and header on both sides. Or,
2. Replace stud on one side and have doorway on other (but also reinforce with extra studs and header).
As this is a furnace room, does it need to have fireproof doors? Is more than one door allowed into the furnace room?
Thank you.
GBunny is offline   Reply With Quote
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
gas furnace vs 1 room electric heater Red Squirrel HVAC 11 10-17-2009 08:23 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Furnace Help tuasoi HVAC 2 11-29-2007 12:54 PM
