2nd Attempt - Concrete Counters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 10:01 PM   #1
2nd attempt - concrete counters
Great Site, ran across it trying to find some answers on Quickete 5000 cure time.
I'm redoing my master bath & figured I'd give concrete counter tops a try. This is my second attempt, I used regular Quickete the first time & it proved to be rather un durable.
Round two is a 2.5" thick by 22" wide x 55" long countertop. & I used Quickete 5000. Rebar and a wiregrid were used for re-enforcement. This time I kept the Quickete 5000 "hydrated" and covered w/ plastic during curing.
So my questions:
1. It will be stained dark, do I need to polish?
2. How about sealing it, can I use some kind of varnish or polyurethane ?
3. It was poured on 2/27, can I hand sand it with a real high grit sandpaper IE 800 grit?
4. I really don't want the face to break apart like the first attempt, I'm hoping keeping it damp and covered will help
5. Quickete 5000 is infused with fiber, I can see some of the fibers at the surface, will they sand off without too much trouble?
Thanks Again
fear_nothing is offline   Reply With Quote
Old 03-04-2011, 10:59 PM   #2
Registered User
Rewards Points: 5,482
Welcome to the forum!
I'll move your post for a better response......
Gary
Old 03-07-2011, 12:48 PM   #3
Well second time was the charm, in retrospect the trowel method was alot of work & upside down method looks alot easier. How about stain suggestions, can I get this locallly IE home depot or lowes. Same applies for a sealer any suggestions?
https://picasaweb.google.com/fear.0....eteCountertop#
Old 03-07-2011, 12:58 PM   #4
waterman1971's Avatar
Rewards Points: 150
Looks pretty cool.
Is that the finished product?
How are you going to move it?
Please keep the pics coming, I for one can't wait to see the end result.
I would like to try this myself.
waterman1971 is offline   Reply With Quote
Old 03-07-2011, 01:40 PM   #5
Thanks!
I've done some further wet sanding. But its pretty close. I'm looking for some pointers on stain & sealer. Also just how smooth should it be before it's stained?
As far as moving? I flipped it up myself after breaking it out of the form. I figure two more buddies and I should be able to move it.
Old 03-07-2011, 02:33 PM   #6
The stains I'm familiar with go in the concrete mix.
You can burn off the fibers that are exposed through polishing.
pyper is offline   Reply With Quote
Old 03-07-2011, 05:27 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
fn,
There is more than one way to color or stain concrete. As mentioned color can be added when mixing. Another is a coating that is painted on and some people call it a stain.
The true way is to use an acid-etch stain. Using acid-etch stain works on a chemical reaction to what's in the concrete mix and I think is the absolute best look of them all. There are several sealers/coatings also available depending on what you desire.
Need more information about your intentions.
XXX
Old 03-07-2011, 09:16 PM   #8
Hi Bud...
I'd like to go with a dark brown color with a glossy finish. I've poured a few test pieces so I can test the result before doing the whole counter top. Is there somewhere I can get small sample before committing to a color? I've looked on Home Depot and Lowes websites, with little success.
Old 03-07-2011, 09:25 PM   #9
Ravenworks's Avatar
Sorry but I have to say that you and your buddies better put your jock straps on. You'll have a counter top that will laast a long tiime.
Ravenworks is offline   Reply With Quote
Old 03-07-2011, 09:50 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow I think so.
Gaye Goodman specializes in acid stained (etched) concrete. Check out her website. I think I saw a place there to buy small samples. She can supply you with sources for everything you need.
Check out her forum for accurate advice on concrete staining. Don't leave us in the dark tho, please check back so we know what you have decided.
http://gayegoodman.com
XXX
Old 03-08-2011, 05:29 AM   #11
Rewards Points: 4,578
concretenetwork.com, decorativeconcreteforums.com, concretelocator.com
Old 03-08-2011, 04:35 PM   #12
mea culpa - forgot fishstone - concretecountertopdesign.com - apologies !
Old 04-05-2011, 03:52 PM   #13
Well its been a month & still no stain.
Gaye Goodman - helpful but doesn't sell stain, she recommended White Cap. They had no interest in selling anything to me.
concretelocator.com - forum site
decorativeconcreteforums.com - promising
www.concretenetwork.com - promising
The Big box HW stores, Home Depot/Lowes look at you with glazed eyes when you ask about stain for concrete countertops. Still looking for a place where I can get a sampler pack of stain without paying a small fortune.
Old 04-05-2011, 04:04 PM   #14
did i recommend gaye ? she's nutz we'd use kemiko before ANYTHING decorative from white cap,,, try http://shop.thestampstore.com/ (doug bannister) OR http://www.murraydecorative.com/default.html (mike murray) i like both but mike supplies more brand names while doug features many private labels
stay OUT of sherwin-williams,,, they'll just point to the h & c display which s/w owns &, after that, their eyes glaze over, too apron/vest store guys are meant to be helpful, NOT knowledgeable, as management won't invest the nec $$$ to train them - its not worth it - not personal, just business,,, feel free to use my name - especially w/mike UNLESS he still hates me if you still have trouble, send me an e & we'll help out w/e-crete's sample pack - think its $ 30 or $ 40
Old 04-05-2011, 04:10 PM   #15
Concrete & Masonry
Rewards Points: 548
You're going to pay a fair amount to have acid shipped to you through the mail or UPS. I'd recommend trying to find it at a local concrete supplier. Many ready-mix concrete plants have a supply division as well.
I usually only use Butterfield color for my acid, but here's a link to a "distributor locator" for LM Scofield, which is basically the same product:
http://sales.scofield.com:8691/
jomama45 is offline   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
House Main Drain Leaking under Concrete Tom738 Plumbing 0 06-01-2010 07:54 AM
