Old 01-12-2011, 08:08 PM   #31
Framing Contractor
26' Steel I Beam
Daniel,
Have you ever spec'd a rectangular piece of steel like this? Or, is it called a tube steel?
I did a job six years ago where we had to take out the back wall of the house that was supporting the second floor and rafters. The owner wanted to have a flush beam in their. Existing joists were 2x10's and there was a 10' addition off the back of the house with 9-1/2" I-joists going into the other side of the steel.
Engineer recommended this 22' clear span 8" x 22" rectangular piece of steel. They welded angle iron on each side for the existing joists and new I-joists to sit on.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-12-2011, 08:49 PM   #32
Carpenter
dtsman's Avatar
26' Steel I Beam
Used steel headers in residential construction many times.
The company that makes the the beam should have the specs. Tell them the length you need and an estimate of the weight it will hold. Double up on the weight part of the calculation and you will have what you need. No one here is going to be able to quote exactly what you need for such a custom application. The steel dealers in your area will.
More things do come into play as well. As argued above.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 01-12-2011, 09:37 PM   #33
26' Steel I Beam
Thanks guys for your input. The steel dealer wouldn't supply the information for me at no cost even if I bought the beam from them. I've gotten in touch with an Engineer and I'll let you know the outcome.
jjohnson112 is offline   Reply With Quote
Old 01-12-2011, 10:25 PM   #34
Civil Engineer
26' Steel I Beam
Joe, the shape you show in the photo is now called HSS (hollow steel shape). It used to be referred to as tube steel. Typically the steel comes in rectangular and circular tube shape, with a variety of standard wall thicknesses available. HSS is very useful for a variety of applications, but is not as efficient as W or S shapes when loaded purely in bending.
Old 01-12-2011, 11:02 PM   #35
26' Steel I Beam
Originally Posted by Daniel Holzman View Post
Yes I am a professional engineer, but I certainly do not think that is a negative. I always try to find the best solution to a client's problem, that is what engineers do
I have been around engineers most of my working life, and I fully agree with Daniel Holzman. I don't understand the adversarial relationship some trades think they must foster with engineers. When you understand what they are trying to accomplish, and to the professional and design standards their designs are held to, then you will start to understand that the vast majority are engineering structures the way they have to.
While it is true that many lumber yards can supply fully documented engineered wood products at no or little additional charge, they must be given correct drawings of the structure to base their calculations on. Site visits without a hefty additional charge are unlikely. In a remodel situation, there may be no drawings reliable enough for any engineer to base beam size upon, and a site visit becomes a necessity
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
AndyGump (01-12-2011)
Old 01-12-2011, 11:05 PM   #36
26' Steel I Beam
We're still dinosaurs out in the field. Everyone I know would still refer to that as (for instance) a "8"x22" x 1/2" square tube" And round shapes are pipe if they truly are IPS (iron pipe size) and mechanical tubing if they are not IPS
Old 01-12-2011, 11:52 PM   #37
Framing Contractor
26' Steel I Beam
What I didn't mention before was that piece of steel is not a perfect rectangle. The outside measured 8" and the middle was 8-3/8" . I put a framing square on it and notice the middle top and bottom was raised. You can see it in the picture if you look closely.
Joe Carola
Old 01-12-2011, 11:56 PM   #38
26' Steel I Beam
It easy to see that it's beat up. That is common, from shipping, handling and torching
Old 01-15-2011, 12:41 AM   #39
26' Steel I Beam
I went to an engineer today and found that I'll be able to use a W12x26 very easily. It would actually be possible to use a W10 if I wanted, but chose to stay with a W12 for good measure. 12' long 4x12's for the other 2 beams connecting to the house.
The Following User Says Thank You to jjohnson112 For This Useful Post:
DangerMouse (01-15-2011)
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 04:55 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Steel beam for deck billybarty Building & Construction 2 08-18-2010 01:27 PM
steel beam length otto man Building & Construction 4 07-27-2008 09:11 AM
