26' Steel I Beam - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 09:51 PM   #16
Concrete & Masonry
Rewards Points: 470
Originally Posted by jjohnson112 View Post
I'm planning to add on a 12' by 26' room addition to the end of my house going out over the driveway. I will be spanning the entire width of the driveway with a 26' steel beam. There can't be any supports in the middle of the beam because of the drive, and the beam can only be 12" tall for vehicle clearance. It is a gable end, so the beam will not be supporting much roof load. What size beam should I go with?
Sorry to be the bearer of bad news, but that won't work for you. Most 12" steel beams will have too much deflection under it's own weight in a span this long. You may have better odds at looking into a multi layer engineered wood beam instead, although it will probably be over 12" high as well.
jomama45 is online now   Reply With Quote
Old 01-11-2011, 10:25 PM   #17
Civil Engineer
Rewards Points: 4,514
Design of a 26 foot steel I beam is a job best left to a professional. I say this because a beam this large is well beyond standard tables, hence requires individual sizing. In order to design such a beam, it is necessary to calculate the dead load and live load on the beam, which depends on house geometry and code mandated design loading conditions.
A steel beam this long must also be checked for buckling, which while not rocket science is not standard DIY computations.
There are four S shapes that meet the 12 inch criteria, and approximately 22 W shapes that could work. It is incorrect to state that Most 12" steel beams will have too much deflection under it's own weight in a span this long. In fact, there are NO S or W shapes that are approximately 12 inches deep that would have excessive deflection UNDER THEIR OWN WEIGHT. Some of them may not meet deflection or strength requirements given the combination of live and dead load, however that is why you hire an engineer to size the beam and design the connections.
In my experience, steel is likely to be less costly than wood for a 26 foot span with maximum depth of 12 inches. However, again that is why you hire an engineer, they will compare the options and select the best value shape.
Old 01-11-2011, 11:03 PM   #18
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
I think that too many assumptions are being made about this beam in question.
We don't even know if it is supposed to be the ridge beam, which if it is would be strange that it could only be 12" high? Why?
Or is it some exotic idea of the OP to hang it on the existing house wall and on the garage door header?
Who knows? I will wait for the OP to respond. I hope he answers some of these questions.
Andy.
AndyGump is offline   Reply With Quote
Old 01-12-2011, 03:56 PM   #19
Most likely, there is a driveway to the side of the house and they are building an addition over the driveway (ala porte-cochere). I saw them a lot in the middle-upscale neighborhoods in Texas.
The reason for the 12" limit is he is trying to match the level of the 2nd floor and that leaves 12" of room between a reasonable height for vehicles.
And yes, a 26' long beam that supports a room above it SHOULD have a professional look at it.
muthian is offline   Reply With Quote
Old 01-12-2011, 05:45 PM   #20
Sorry I'm wasting everyone's time. The main reason I ask this question is the fact that I wanted to get a "round about" price from a local steel beam fabricator without paying $300 in engineer's fees just to find out that I want to go a different route because the size of the beam is so big it won't be worth the money. In order to get a "round about" price I need a "round about" steel beam size. I was assuming I could get by with either LVL beams for the outside wall beams or even 3-ply 2x12's, but would be having everything spec'd by an engineer before beginning the project. I will be over killing the two columns using either 18" or 24" diameter reinforced concrete columns on top of a footing on clay soil. Keep in mind the beam must be a W12 in order for vehicle clearance. I live in Terre Haute, Indiana...
jjohnson112 is offline   Reply With Quote
Old 01-12-2011, 05:49 PM   #21
No big deal. Vague description usually begets questions and responses. If you could provide more detail on exactly what the beam is supporting, etc then guesses could be made. Still a lot of variables that need to be dealt with before an accurate estimation can be made.
Old 01-12-2011, 06:04 PM   #22
The beam will be at the end of the addition. Assume you're pulling into a basement garage at the end of your house. It is a 6 and a 1/2 foot tall by 16 foot wide garage door with a 3-ply 2x12 header (we may have to add a flitch plate for strength). The wall extends 5 feet on each side of the door to make my 26' wide. I will be using wood beams extending out 12' from the end of the walls, resting on top of the basement walls and the concrete columns. The steel I-beam will be spanning from one column to the other overtop of the driveway. I will then use 2x10 floor joists running from the beam to the existing wall 16 OC. The gable end will be on top of the beam, so the side walls will be holding most of the roof load, while the beam will have half of the bedroom floor load and the existing wall will have the other half of the floor load. (I think thats right?)
Old 01-12-2011, 06:05 PM   #23
the Musigician
DangerMouse's Avatar
You're not wasting our time. The guys here love a good challenging thread.
Gives them all a chance to voice their opinions when not enough details are there to work with. It happens all the time, don't worry about it.
I recently finished a project similar to this, and MY engineer drew up two 2x12s on the outer, one indide, one outside bolted together, and double 11 7/8" LVLs heavily bolted together for the ridge. Then the trusses went up.
You might find that this may end up being the route you want to go. However, once you start and have the drawings done up, you'll find the inspectors a lot easier to get along with if you have the engineer's stamp on it. Well worth the $300 to have them run the numbers to keep it strong, and your family safe.
DM
Old 01-12-2011, 06:21 PM   #24
Just so everyone knows, I'm not trying to find a shortcut to finding the beam size by going through a DIY forum. I'm simply wanting something to give me an estimate as to about the size so I can see if this project is even worthwhile. Engineers have to stamp anything that gets put up in our area, so in order to start the job, I will have to have plans and everything stamped.
Old 01-12-2011, 06:34 PM   #25
Framing Contractor
I understand that. The simple and safe answer for is that you cannot get it here. No one here is qualified to size such a beam. If someone did, would you trust that size from someone on the internet?
I've been framing a long time and what you have here is a big project and you are going to have to pay to get the answer. It's not just a little framing project with a beam that size.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-12-2011, 06:41 PM   #26
Concrete & Masonry
Rewards Points: 470
I'll give you the fact that I may have "exaggerated" on the deflection comment. When loaded though, most 12" beams would have more deflection than I would be comfortable with, regardless of if they met typical deflection standards or not.
As for the engineer selling value, I think that you may be the only professional here that thinks that. Engineer's typically do whatever's easier for themselves and have little regard to saving either the contractor or end consumer money. Maybe your own approach is different, but my experiences would say that you're in the minority if that's the case.
Steel would be cheaper than wood in this scenario?? Maybe it appears that way to you, but in reality, if you figure in the fact that most any lumberyard will do the engineering, or at least get the engineering from the manufacturer, included in the cost of the wood beam, wood almost always comes out cheaper. I know you don't like to hear this, because it takes business away from folks like you, but it is oftentimes the most efficient approach financially.
Old 01-12-2011, 06:46 PM   #27
Concrete & Masonry
Rewards Points: 470
You may want to consider going to a lumber yard to have them price out the whole package for you. As I stated above, they will generally spec the beam for you as part of the cost of the beam. Most of the time, they can get a stamped drawing with the calcs as well, if you're required to present the to your building department.
One other thing to consider in a wood beam is that it is fairly simple & routine to hanger the floor joists off of the beam, giving you much more clearance underneath. For example, if the wood beam was spec'ed out to be X layers of approx. 16" high LVL, you'd only have 7" of the beam BELOW the bottom of floor joists.
Old 01-12-2011, 07:19 PM   #28
OK am I missing something here ( I usually am) but if you are going to have a 5 foot wall on each side of the 16' door why do you need a 26' beam and not a 16' beam?
warnerww is offline   Reply With Quote
Old 01-12-2011, 07:31 PM   #29
joed's Avatar
Rewards Points: 11,520
Go and ask the beam supplier. He probably has good idea of what you need.
Old 01-12-2011, 07:52 PM   #30
Civil Engineer
Yes I am a professional engineer, but I certainly do not think that is a negative. I always try to find the best solution to a client's problem, that is what engineers do.
Now as to this particular beam. I ran a few calculations just for fun, and it is clear that the 12 inch deep limitation, if it is actually controlling, would require a wide and expensive Glulam, based on 40psf load. Obviously I don't know the exact load on your structure, and this is absolutely not a design, but I checked a few 12 inch deep steel beams and they appear to work adequately from a deflection and strength standpoint.
And steel is relatively inexpensive. I recently installed a 12 lb/foot steel beam, and it cost about $300 for 20 feet, which works out to be around $1.50 per lb, cut and drilled. A larger beam in the 26 foot range would be less costly per pound, depends on the availability of steel in your area. At $1 lb, you would end up paying perhaps $600 for the beam. If you can get a working Glulam for less, go for it, I don't own any steel stock. Simply saying that based on some preliminary calcs, and lots of personal experience, I expect the steel beam to be considerably less costly than the equivalent Glulam due to the span. But again, you are going to have to hire an engineer to design it, and they can tell you for sure which size you need, and which option is more cost effective.
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 04:55 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Steel beam for deck billybarty Building & Construction 2 08-18-2010 01:27 PM
steel beam length otto man Building & Construction 4 07-27-2008 09:11 AM
