Old 10-04-2012, 10:24 PM   #1
24'x14' out building
Okay the rough size is as stated some more info is, its stuco mostly just studs on the inside with to interior walls to create a small garden work room, about 5'x6' didn't measure this as these two walls will be demoed. I am looking to put in a wall the full width about 6'-8' from the back side for storage for my wife. The rest of the building will be my work shop. The work shop will be insulated and heated/cooled. What I need help with is should I install a vapor barior? Should I install insulation in the storage area? The storage area has its own door and the work shop has two doors
redman88 is offline   Reply With Quote
Old 10-04-2012, 11:02 PM   #2
AHH, SPANS!!!
May I ask, Where are you located?
hand drive is offline   Reply With Quote
Old 10-04-2012, 11:11 PM   #3
New mexico
Old 10-05-2012, 02:49 PM   #4
Bump for more info
Old 10-05-2012, 04:23 PM   #5
Not sure about new mexico but here it is done, insulate part for the shop then another part uninsulated for storage.
mae-ling is offline   Reply With Quote
Old 10-06-2012, 03:48 PM   #6
the question wasn't about if it could just wanted to know the best way to insulate so there would be fewer problems with moisture.
Old 10-06-2012, 09:49 PM   #7
I think that it is always better to insulate, it makes the space more comfortable even for the area you are not conditioning. Although I do not live in a dry climate, my understanding is that in a dry climate any moisture generated from the inside will easily vent out, therefore no vapor barrier. Also, you are not likely to generate the moisture in the shop/storage shed that you would in the residence.
TheCamper is offline   Reply With Quote
Old 10-06-2012, 11:54 PM   #8
well took another look, and it looks like i should redo the roof, its a tar with Lava rock, though not much lova rock left. So i am thinking that i will take all that off, and install a metal roof, and some roof vents and proper soffet vents since those were not installed with the soffets that were install. this same treament will eventuly go to the house as well. No atic vents there either.
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Effect of Heat Load of Tenants on a Commercial Building mphoenix HVAC 1 04-20-2011 04:59 AM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 08:28 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
