24 Foot Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 10:11 PM   #1
24 foot span
i am planning to build 24x32 garage, how do i install 24 ft ceiling joist? can they be spliced? any suggestions appreciated thanks judesson
judesson is offline   Reply With Quote
Old 02-02-2011, 10:32 PM   #2
Experienced
Jackofall1's Avatar
That would typically be a truss design to achieve the 24' free span, typically by a designer or architect.
Mark
Old 02-03-2011, 01:20 AM   #3
Rewards Points: 502
Pre-made trusses is the way to go with something like this. They will come engineered for your local snow and wind load.
If you want to build it yourself, do the research (look up the span tables and codes) or hire someone who knows their stuff.
at 24' (make it 26' with the eaves), if you want open storage above, engineered wood I-beams are almost mandatory, but the price will add up quick. another option would be a steel 32' I-beam running the length with a post or three in the middle. That way you only have to span 12'. that would let you buy 14' lumber and have a generous eaves overhanging.
forresth is offline   Reply With Quote
Old 02-03-2011, 01:49 AM   #4
Framing Contractor
You buy 24' joists that are properly sized by an architect or engineer. Or you can use trusses that are designed by an architect or engineer.
Joe Carola
Joe Carola is offline   Reply With Quote
15 foot span of 2x8 floor ronchapin6 Building & Construction 1 09-11-2010 03:40 PM
a 30 foot span trusses able to hold 6 feet of snow bertr Roofing/Siding 2 07-16-2010 09:19 PM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 04:41 PM
Platform across a 9 foot span Hogan-s Carpentry 1 09-19-2008 07:46 AM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
