24 Or 16 Inch Spacing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 02:44 PM   #1
24 or 16 inch spacing
Hi,
I will be building some perimeter walls in the basement, so they are not load-bearing. However, I want to use 2x6 because I will be insulating with batt and want to get the R22 value.
Since 2x6 are expensive, I am thinking of going to 24 inch spacing. I will be using 1/2 inch drywall.
I have heard that 24 inch centres can produce a wavy look in the drywall. I suppose I could add some cross pieces.
Opinions ?
thanks.
Mike Mike is offline   Reply With Quote
Old 02-16-2011, 06:13 PM   #2
Originally Posted by Mike Mike View Post
Hi,
Opinions ?
thanks.
5/8 drywall
mrgins is offline   Reply With Quote
Old 02-16-2011, 06:43 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
5/8" drywall. It doesn't cost that much more.
XXX
Old 02-16-2011, 07:11 PM   #4
Studs aren't that expensive. Would 5/8 sheetrock be any cheaper than adding a couple studs?
Make sure you crown your studs and before the sheetrock goes on check for bows by putting a long level or straight edge across the wall to see if the any studs stick out farther than the others. To fix them you can use a planer and plane down studs that are sticking out or use butt-strips to fur out studs that are bowed in.
I've always heard them called butt-strips. I don't know if there is a different name for them. They are strips of cardboard commonly used by sheetrock hangers.
elarreau is offline   Reply With Quote
Old 02-16-2011, 11:14 PM   #5
Registered User
Rewards Points: 5,492
Many people don't realize drywall has a machine "grain" to it, making it 3 times stronger in flexural strength when installed with studs perpendicular to it's long side rather than up and down on a side wall.
Notice the effective stiffness of 1/2" vs. 5/8" in the second chart; http://docs.google.com/viewer?a=v&q=...U1o3kfoOlKl-7Q
Use a sill sealer under the p.t. bottom plate for a thermal and capillary break. Foam board on concrete, no air space, f.b. the rim joists and air seal, use ADA on drywall.
Gary
Old 02-16-2011, 11:51 PM   #6
It is up to you. I have no problem with 24 centers and 1\2 drywall. I feel you get more R value in your wall with 24 centers (less wood more insulation). I think people who use 5/8 on the wall are nuts and the people who use 5/8 on the wall think I am nuts for using 1/2"
warnerww is offline   Reply With Quote
Old 02-17-2011, 12:14 AM   #7
Use 2x4 and hold 2" off the wall. Either spacing is fine for 1/2" drywall. 2X4 walls with r-23 batts is going to be better than 2x6 with 23 the batts will touch behind the studs and break the thermal bond.
ubenhad4 is offline   Reply With Quote
Old 02-20-2011, 04:25 PM   #8
Rewards Points: 1,092
Age-old dilemma, no clear answer. When in doubt, overkill w/ 5/8". Or, accept possible waves as adding an aesthetic, oceanic parameter to the home.
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
14 inch tank on a 12 inch bowl? jimmybush Plumbing 2 10-02-2009 01:13 PM
1 1/2 inch zone valve - can't find BOUTYM HVAC 2 11-20-2008 10:03 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 08:53 PM
