-   -   23" and 36" overhang for aluminum soffit (http://www.diychatroom.com/f19/23-36-overhang-aluminum-soffit-143575/)
jogr 05-12-2012 09:06 PM
I'm installing aluminum soffit on my house which has 23" overhang in most areas and a 36" overhang in part. All the directions I've found simply show installing the frieze runner (or J) to support it at the wall and nails or screws and the fascia to support the outside edge. None seem to mention just how long the aluminum soffit can be before it needs additional intermediate support.
How far do you span aluminum soffit before adding intermediate support?
joecaption 05-12-2012 09:09 PM
Just split the differance. (run one down the middle)
woodworkbykirk 05-12-2012 09:59 PM
joe's right, once its over 16" it needs another nailing edge to fasten it to otherwise it will sag
cleveman 05-12-2012 10:08 PM
I've run it 24" on numerous occasions without incident. That is pretty standard. I also run it 4' or more for recessed entries, but they are only 3-6' wide.
jogr 05-12-2012 10:11 PM
So if 16" is the maximum span then I need two intermediate supports on the 36" overhang, not one right?
mae-ling 05-13-2012 10:16 AM
24" is done all the time here, have seen up to 4' over door entries and the like. I always allow for no more than 24" unsupported.
With 36" I would run one row of colored screws at 18"
