#16 | |
22x14 DECK W/ROOF SLIGHT SWAY NEED HELP FROM EXPERTSQuote:
#17 |
Appreciate your response. The vinyl siding when you're talking about "nailing to tight" assume you're talking about expansion, etc. When installing on the side of the house that seems reasonable. However, when installing in the ceiling is it that important? The other problem is that the trusses are on 24 inch centers and the vinyl is so thin it seems to me there may be a tendency for it to sag. Thoughts??
#18 | |
#19 | |
Last edited by clfdpops1; 06-03-2012 at 04:46 PM. Reason: want to add a couple more photos |
#20 | |
Why not let in the 2x underneath the framing? |
#21 |
By the way, I am a pro that builds a few decks each year.
The reason that the pros walked away is the obsessive detail to which you have gone. That and the beam being covered with OSB is not going to hold up with water coming from the top. You need a hand when installing vinyl soffiit to start with. After the first piece you won't. |
#22 | |
Gary "You get what you pay for, and sometimes free costs more!" |
#23 |
Mod
I don't know what else he could do at this point with the decorative columns in the way.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#24 |
The important diagonal bracing is from your beam to the columns. Imagine pushing on the side of your deck up in the air at the drop beam. What keeps the deck from being pushed? With a roof on it it's more subject to lateral movement.
Check out this document http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf especially page 14. It shows the diagonal bracing requirement for elevated decks. This is what Daniel Holzman was telling you. The cross bracing is typically metal straps that connect the top of one joist to the bottom of an adjacent joists. Then you connect one to the bottom of the same joist to the top of the adjacent joists. Form an "X" so that it keeps the joists from rotating/leaning.
| The Following User Says Thank You to GBrackins For This Useful Post: | clfdpops1 (06-09-2012) |
#25 | |
Other than figure out a wall to properly support the deck (which I certainly won't give suggestions on) and reconstruct the columns to include the diagonal bracing. If it were my deck I'd contact a professional engineer and get them to come to the site for a consult, and see how they would fix it. That or potentially risk having it all come down in a high wind event. In a partially enclosed structure you have more wind force than a typically roof because the wind acts on the roof and the ceiling at the same time. Kinda the same as with a sail boat. The goal is to find a way to keep the boat from moving when the wind acts on the sail.
#26 |
Mod
He may be able to do something with a steel gusset on the post to beam connection and maybe stay within the box.
Is that glulam treated?
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. Last edited by kwikfishron; 06-03-2012 at 07:04 PM. |
#27 |
When you talk about 2x are you talking about installing firring strips on 16inch centers perpendicular to the trusses and then nailing the vinyl to it?
#28 |
Thanks for providing the reference. I thought of that as well, as another gent mentioned the decorative columns may be in the way. However, the boxes I've built above the columns on the lower structure are about 2 feet in length so I may be able to pull off the CDX on one side and attach the diagonal member about 3' long to an existing bolt (or drill another hole if the existing bolt is 90 degrees out of phase) and drill a hole in the glulam and put another 1/2 x 6" bolt and nut on it. That might do the trick. What about the upper boxes? If I remember right they are only about 16 inches high before I run into the trusses, or should I even put the diagonal cross members on the upper beams?
#29 | |
#30 | |
Understand what you're talking about when you talk the sail issue and associated wind lift on the roof which is why I added all the extra strapping. Last edited by clfdpops1; 06-09-2012 at 11:53 AM. Reason: update |
| Tags |
deck building, deck sway, knee braces ![]() |
| Display Modes | |
| Pergola over existing deck | cpfullback | Building & Construction | 0 | 08-04-2011 12:36 PM |
| Deck Staining Nightmare | steven994 | Painting | 2 | 06-17-2010 08:21 AM |
| deck sway | redroc25 | Building & Construction | 11 | 09-13-2009 03:46 PM |
| Building a new deck....and creative uses of granite scrap in outdoor living space | Rhizzlebop | Building & Construction | 9 | 05-15-2009 12:17 PM |
