22' Loft - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 12:17 PM   #1
22' loft
I have a loft that comes out from the wall 61/2 ft. The loft goes from wall to wall 22ft. It has a 4x6 cedar beam on the front with a support beam in the middle. I would like to take out the beam and replace the cedar beam with a steel I-beam. The loft only has decorations on it and the only access to the loft is through the attic. What size I-beam do I need. Will a 3/8" I-beam work?
jonniebrook is offline   Reply With Quote
Old 01-17-2012, 01:42 PM   #2
Rewards Points: 1,092
I'd suggest you ask an engineer who can look at exactly what you have. I don't know what you mean by "3/8 inch I-beam", as I-beams come with various flange and web thicknesses, as well as widths and heights. If you google for load carrying tables, you can get a fair idea of comparable members. Now....As a guess from having looked at tables a fair amount (I am no engineer), an I-beam that is as wide and high as your cedar "beam", and has 3/8" thick flanges and web will carry far more load than the cedar, and I suspect a 1/4" is plenty. If you don't pay an engineer a few bucks to look, go heavy on the beam; it's cheap.
Old 01-17-2012, 04:02 PM   #3
Civil Engineer
Rewards Points: 4,520
Steel I beams are not sized as 3/8", rather they are sized (at least in the United States) either as S or W shapes, with the nominal depth first, then the weight in lbs per foot. So for example, a W6x15 means the beam is nominally 6 inches deep (actually it is 5.99 inches) and is nominally 15 lbs per foot. All the other properties of such a beam are found on standard tables of steel beam properties.
As to what size beam you need, well we have no idea if the existing cedar beam is properly sized, so it would be dangerous and foolish to size an equivalent steel beam over the internet. This is really a job for a structural engineer or an architect, but if you don't care to pay for one, you may be able to go to a steel fabrication shop, show them plans for your house, and they may have an engineer available to size the beam for you. In most jurisdictions, you need a stamped plan to replace a header with another beam, course you may not need a permit, or you may be planning to do this job without one.
I realize you didn't ask, but just a word of advice, if you do this work yourself, make sure you use proper temporary support while replacing the beam. Also, make sure you carefully think through how you plan to attach the steel beam on either end, you may want to get the beam predrilled so you can use lag bolts or similar when connecting the beam to the posts, assuming you use wooden posts as supports.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
mae-ling (01-17-2012)
Old 01-17-2012, 04:08 PM   #4
I don't know what your intent in replacing the beam is, but if a laminated beam would work, they can size them at the lumber yard with software from the manufacturer.
pyper is offline   Reply With Quote
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 07:29 PM
what is better for a small room " junior loft or a full loft ?" irishguy76 Carpentry 3 05-23-2011 10:17 AM
Twin Size Loft Bed construction.. for a dummy what_silliness Building & Construction 2 01-15-2011 03:53 PM
Hanging loft from glulam beam, pics inside. wackerjr Building & Construction 20 01-05-2011 09:55 PM
How would i finish this loft???? (pics) oregonrebel Building & Construction 3 03-31-2007 09:01 AM
