20' Span Joist Requirement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 05:19 PM   #1
weekend warrior
Rewards Points: 150
20' span joist requirement
I want to add some storage space in the corners of my garage (see pic). I'm not having any luck calculating the required joist size for the span (the "red" in the pic). It will also hold my aluminum garage door/rails.
I have lots of 2x10x10 sitting around, was hoping to maybe sandwich three of those together? Or get some LVLs if I have to. Was hoping to use one joist, maybe two if I have to? It will be for light storage (kids bikes, junk, no human occupation, etc.)
any insight would be appreciated.
johnny331 is offline   Reply With Quote
Old 09-18-2010, 06:37 PM   #2
Registered User
Rewards Points: 5,212
1. Weigh the garage door, without the spring assist.
Gary
Old 09-18-2010, 11:56 PM   #3
Rewards Points: 502
you'd have to make some complex truss full of diagonal braces to it to do what you'd want I'm guessing.
I had something similar on a previous house of mine, but it had a big I beam instead of a couple patched together 2x10s
forresth is offline   Reply With Quote
Old 09-19-2010, 08:56 AM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
Avoid the hassle and do it right from the get go: find a local engineer that specializes in this sort of thing. It wouldn't be that expensive.
Aggie67 is offline   Reply With Quote
The Following User Says Thank You to Aggie67 For This Useful Post:
jlhaslip (09-19-2010)
Old 09-19-2010, 12:09 PM   #5
Rewards Points: 502
I've been giving this some thought.
simple span tabless for ceiling joists say a 20' 2x10 would be OK @16" OC,
http://www.wclib.org/pdfs/SimpSpanTbls.pdf
but you want to carry it all in one 1 joist of unknown grade that has been cut in half then patched.
my gut tells me if you take 4 of 10' 2x10s, one spanning the joint of the other 2 evenly, and the last cut in half to even it out you should be in the same ballpark for strength as 1 20', if you join them tightly and properly.
that way you'd need about 6 joists, or 24 2x10s
if you can to make a wooden I beam, you might be able to get away with doing it like you want, but it wouldn't be simple.
you could take 1 joist as I described above, for the web, then take 4 above and below, staggering all of the joints, 8 total to be the flanges, for a total of 12 boards that way.
a truss built out of 3 (or 6)as horizontal elements and some shorter 2x4 or 2x6s as the diagonal elements would probably work too.
basically, I'm saying, it can be done, but just get a beam and do it the right way
Old 09-19-2010, 12:24 PM   #6
I may misunderstand the question. Couldn't you support the cross piece from the rafters above?
eastside is offline   Reply With Quote
Old 09-19-2010, 01:16 PM   #7
Rewards Points: 111
I misunderstand the pic. Are you talking about storage space at the back of the garage area up in the corners?
luvdairish is offline   Reply With Quote
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 05:41 PM
Joist size and span under tile. jackson_norman Building & Construction 9 08-12-2009 09:10 AM
Max span length on 4-2x10 fir beam? gadget463 Building & Construction 4 08-03-2009 06:51 PM
2x12 joist span phillybr Building & Construction 3 03-31-2009 10:38 AM
