20 Minute Fire Door? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 07:42 PM   #1
pwa
20 minute fire door?
Hi to all, a contractor installed a door leading from my house to my garage and told me it is a 20 minute fire door.I have my doubts, there are no stickers or identification anywhere on the door.Aside from the fact that this door is solid and the other 2 he installed in the garage are 1/2 glass they appear to be the same.I am thinking about pulling the hinge pin and comparing the wieght unless theres an easier way? Thanks in advance
pwa is offline   Reply With Quote
Old 10-02-2011, 08:51 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
is it a exterior door with a frame that has a sil, door sweep and weather stripping, if so this door is fine. if its just a interior prehung thats solid its no good
codes specifically require a exterior grade door with weatherstripping so to prevent toxic fumes from entering the living space
woodworkbykirk is offline   Reply With Quote
Old 10-02-2011, 08:54 PM   #3
Rewards Points: 150
Yuuup +1.
Most exterior steel doors qualify.
OhioHomeDoctor is offline   Reply With Quote
Old 10-02-2011, 09:01 PM   #4
Too Old
You should have a metal plate on the hinge side of the door stating the door rating
http://www.lovettc.com/FireRatedDoors.pdf
If the plate was removed, too bad I learned years ago, never let the painter remove a plate. You will only have a fire rated door if the plate is still attached. Any fire rated door will have a plate see page 3 on the above link.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-02-2011, 09:54 PM   #5
pwa
Thanks Guys, all 3 of the doors have a plate on the bottom(sil ?) and a door seal that looks like a hollow tube. All appear to be wood with metal on both sides. The garage-house door doesnt look like anything special or diffrent than the exterior doors on the garage.
Old 10-03-2011, 09:16 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
A solid core flush wooden door without glazing is usually accepted as a 20 minute door even if it does not have a tag from a testing agency. It needs to be cased on both sides. It would need a latch bolt with a 1/2 inch minimum throw and may require a thicker stopping. Clearance from the bottom of the door to the floor or threshold would need to be less than 3/4 inch. Much depends on what your local "authority having jurisdiction" will accept. In any case, the rating requirement of the door is driven by the rating of the wall assembly it is installed in. I've not heard of a weatherstrip requirement even on 2 or 3 hour doors.
Old 10-03-2011, 09:42 AM   #7
AGWhitehouse's Avatar
2003 International Residential Code:
R309.1 Opening Protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 1-3/8 inches (35mm) in thickness, solid or honeycomb core steel doors not less than 1-3/8 inches (35mm) thick, or 20-minute fire-rated doors.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 10-04-2011, 10:23 AM   #8
Originally Posted by EmeraldTaylor View Post
It means what it says, NO GAPS, but there is are foams/caulks used for firewalls that may quality. Check lumberyards, and check local code for approval.
Huh? Is this in the right post?
Old 10-04-2011, 08:44 PM   #9
Rewards Points: 372
I know nothing about residential doors, but commercial 2 or 3 hour doors do have a weatherstrip. The weatherstrip is part of the fire rating.
No decal, no rating and the door needs to be replaced.
fireguy is offline   Reply With Quote
Old 10-05-2011, 09:07 AM   #10
I've worked with plenty of fire doors of all ratings and have never seen a common hinged fire door with "rated" weatherstrip. Plenty of restrictions on clearances: door to frame, door to floor, door to stop. Restrictions on glazing sizes and types, but no weatherstrip. Rated astragals can be installed on pairs of fire doors if the gap between them exceeds 1/8" measured on the outward side of the slab. People may call that a weatherstrip. In fact, adding weatherstrip to a rated door/jamb assembly without the express permission of the manufacturer would void the rating. I'm looking at the 2010 edition of NFPA 80 and find no mention of weatherstrip. Can you cite the section number where it may be?
Agreed, the rating tag must be in place and legible to satisfy the AHJ.
Old 10-06-2011, 11:33 AM   #11
Rewards Points: 372
the first step is to determine the referenced code in your jurisdiction. The previous poster referenced NFPA 80, 2010. That edition may or may not be accepted in your jurisdiction, or the an ICC code may be used. I am in buck camp, and do not have the information on my laptop. Contact the local building official.
Old 10-06-2011, 08:34 PM   #12
pwa
wow!!! I cant believe how damn complicated everything is, Thanks for all the input
Front Storm Door Won't Latch sciron General DIY Discussions 6 02-21-2011 10:47 AM
Security screen door dangerp Carpentry 4 09-22-2010 08:02 PM
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 09:17 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
