-   -   20 minute fire door? (http://www.diychatroom.com/f19/20-minute-fire-door-119025/)
pwa 10-02-2011 07:42 PM
Hi to all, a contractor installed a door leading from my house to my garage and told me it is a 20 minute fire door.I have my doubts:wink:, there are no stickers or identification anywhere on the door.Aside from the fact that this door is solid and the other 2 he installed in the garage are 1/2 glass they appear to be the same.I am thinking about pulling the hinge pin and comparing the wieght unless theres an easier way? Thanks in advance
woodworkbykirk 10-02-2011 08:51 PM
is it a exterior door with a frame that has a sil, door sweep and weather stripping, if so this door is fine. if its just a interior prehung thats solid its no good
codes specifically require a exterior grade door with weatherstripping so to prevent toxic fumes from entering the living space
OhioHomeDoctor 10-02-2011 08:54 PM
Yuuup +1.
Most exterior steel doors qualify.
havalife 10-02-2011 09:01 PM
You should have a metal plate on the hinge side of the door stating the door rating
http://www.lovettc.com/FireRatedDoors.pdf
If the plate was removed, too bad I learned years ago, never let the painter remove a plate. You will only have a fire rated door if the plate is still attached. Any fire rated door will have a plate see page 3 on the above link.
pwa 10-02-2011 09:54 PM
Thanks Guys, all 3 of the doors have a plate on the bottom(sil ?) and a door seal that looks like a hollow tube. All appear to be wood with metal on both sides. The garage-house door doesnt look like anything special or diffrent than the exterior doors on the garage.
Maintenance 6 10-03-2011 09:16 AM
A solid core flush wooden door without glazing is usually accepted as a 20 minute door even if it does not have a tag from a testing agency. It needs to be cased on both sides. It would need a latch bolt with a 1/2 inch minimum throw and may require a thicker stopping. Clearance from the bottom of the door to the floor or threshold would need to be less than 3/4 inch. Much depends on what your local "authority having jurisdiction" will accept. In any case, the rating requirement of the door is driven by the rating of the wall assembly it is installed in. I've not heard of a weatherstrip requirement even on 2 or 3 hour doors.
AGWhitehouse 10-03-2011 09:42 AM
2003 International Residential Code:
R309.1 Opening Protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 1-3/8 inches (35mm) in thickness, solid or honeycomb core steel doors not less than 1-3/8 inches (35mm) thick, or 20-minute fire-rated doors.
AGWhitehouse 10-04-2011 10:23 AM
Originally Posted by EmeraldTaylor (Post 741825)
It means what it says, NO GAPS, but there is are foams/caulks used for firewalls that may quality. Check lumberyards, and check local code for approval.
Huh? Is this in the right post?
fireguy 10-04-2011 08:44 PM
I know nothing about residential doors, but commercial 2 or 3 hour doors do have a weatherstrip. The weatherstrip is part of the fire rating.
No decal, no rating and the door needs to be replaced.
Maintenance 6 10-05-2011 09:07 AM
I've worked with plenty of fire doors of all ratings and have never seen a common hinged fire door with "rated" weatherstrip. Plenty of restrictions on clearances: door to frame, door to floor, door to stop. Restrictions on glazing sizes and types, but no weatherstrip. Rated astragals can be installed on pairs of fire doors if the gap between them exceeds 1/8" measured on the outward side of the slab. People may call that a weatherstrip. In fact, adding weatherstrip to a rated door/jamb assembly without the express permission of the manufacturer would void the rating. I'm looking at the 2010 edition of NFPA 80 and find no mention of weatherstrip. Can you cite the section number where it may be?
Agreed, the rating tag must be in place and legible to satisfy the AHJ.
fireguy 10-06-2011 11:33 AM
the first step is to determine the referenced code in your jurisdiction. The previous poster referenced NFPA 80, 2010. That edition may or may not be accepted in your jurisdiction, or the an ICC code may be used. I am in buck camp, and do not have the information on my laptop. Contact the local building official.
pwa 10-06-2011 08:34 PM
wow!!!:eek: I cant believe how damn complicated everything is, Thanks for all the input
