2 Story House - Outer Sheathing Made Of... Fiberboard? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2016, 10:26 PM   #1
Rewards Points: 86
2 story house - outer sheathing made of... fiberboard?
1977 house, 2 story colonial. I opened up some drywall on an external wall and pulled back the insulation. I noticed the board nailed into the studs from outside was not plywood or OSB; in fact it was a flimsy fiber board like the backing of the cheap furniture you buy at Ikea. I'm pretty sure there was not an additional layer of sheathing... just the aluminum siding next. Isn't the plywood/OSB what gives the house a lot of its structural strength from swaying and tipping over? If relevant, basement is a full basement, and attic is trusses.
odie91 is offline   Reply With Quote
Old 04-04-2016, 11:11 PM   #2
Rewards Points: 2,092
Re: 2 story house - outer sheathing made of... fiberboard?
In that construction plywood is normally at the corners.
Old 04-05-2016, 05:46 AM   #3
Ah.... If it ain't broke don't fix it...
ron45 is offline   Reply With Quote
Old 04-05-2016, 08:08 AM   #4
Rewards Points: 14,312
Likely it was Celotex.
http://www.blueridgefiberboard.com/p...ving-r-values/
Old 04-05-2016, 08:18 AM   #5
They did some funky stuff back then to try and cut cost.
1/2" sub flooring with particle board over that, Quest tubing, stapled vinyl siding and shingles come to mind.
Old 04-05-2016, 09:28 AM   #6
Rewards Points: 162
My house has the same stuff on the 2nd floor-celotex fiber sheathing. The 2nd floor was an addition put on in the early 90s, they used plywood at the corners. It's not "the best", but there's plenty of homes that are sheathed with it.
roobinsteen is offline   Reply With Quote
Old 04-05-2016, 10:02 AM   #7
Rewards Points: 1,300
My 1959 built ranch has the same material. Walls are still straight and plumb. Plywood at the corners and at two locations down the length of a 44' long wall.
danpik is offline   Reply With Quote
new roof for an old 1 and 1/2 story house michigan Roofing/Siding 5 09-20-2013 08:02 AM
I want to zone my single story house, is it possible? option12 HVAC 7 08-15-2012 11:05 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
Effeciently cooling a 2 story house??? jsalassi HVAC 4 06-10-2006 11:35 AM
