2 Questions Regarding Weepscreed/stucco Netting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2014, 06:36 PM   #1
Rewards Points: 262
2 questions regarding weepscreed/stucco netting
House was built in 1965 in southern Calif. Stucco mixture was put on house clear down below sillplate covering concrete raised foundation. Over the years moisture creeping up through stucco into rim joist/sill plated rotted the wood.I have replaced bad wood. I have taken off crumbling stucco and rusty stucco netting/black paper. I added weepscreed but just below weepscreed is original stucco that goes down to bottom of raised foundation. Cosmetically it looks better than the exposed concrete foundation. I dont think the stucco can hurt anything anymore with weepscreed installed.
1.) Do I absolutely take off old stucco? None of the existing stucco on original concrete is loose or crumbly. It has a better finished look to it.
2.) How far up the wall do I take old stucco off? I have found rusty stucco wire upwards of 4' in the wall. And then I start to seen clean wire. Check out photos. One photo is an open vent and if you look close you can see existing stucco on the concrete foundation. I started taking that stucco off but the exposed concrete foundation just doesnt look that nice. Any thoughts?
2 questions regarding weepscreed/stucco netting-house-floor-plans-185.jpg   2 questions regarding weepscreed/stucco netting-house-floor-plans-184.jpg
Pawl is offline   Reply With Quote
Old 01-22-2014, 10:57 AM   #2
I would not completely remove the remainder of the stucco, so long as the stucco particles are not loose and at risk of disintegration. How is the slope in that area? Is water likely to accumulate and cause the stucco to further disintegrate?
I inspected a residential property that had a similar situation.... My recommendation was to remove only the loose/exposed particles.
Jack Haddad
Www.superhomeinspections.net
Www.superiorhomesolutions.net
jackmd1 is offline   Reply With Quote
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
Mobile Home Carpentry questions immeraufdemhund Carpentry 3 11-19-2010 06:52 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-24-2010 11:53 PM
A few roof questions before I begin... chrisexv6 Roofing/Siding 6 05-02-2010 06:16 AM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
