2 Inch Styrofoam Sheets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 09:30 AM   #1
2 inch styrofoam sheets
is there a product that can be applied over styrofoam to make it fire proof besides sheet rock?
14bill is offline   Reply With Quote
Old 08-22-2010, 11:40 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
depends on how fire proof it has to be,metal,fire resistant plywood,fiberglass panels...depends
Tom Struble is offline   Reply With Quote
Old 08-22-2010, 03:43 PM   #3
all I know is that the styrofoam has to be covered for house insurance
Old 08-22-2010, 06:19 PM   #4
Where is it installed ?
Why not use sheetrock ?
Old 08-22-2010, 07:08 PM   #5
Registered User
Rewards Points: 5,482
Mineral fiber insulation, wood panel, particleboard, hardboard,and steel: http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
Be safe, Gary
Old 08-23-2010, 05:08 PM   #6
Be safe, Gary
Thanks for all the imput!
I have decided to go with sprayed on foam that is then sprayed with a fire rated product. This also satisfied the code.
Old 08-24-2010, 10:52 AM   #7
Registered User
You are welcome, glad we could help!
Be safe, Gary
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
14 inch tank on a 12 inch bowl? jimmybush Plumbing 2 10-02-2009 01:13 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 08:53 PM
