1st Stucco Job, Need Some Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 04:36 PM   #1
1st stucco job, need some help
hey there,
i have a small post and pier foundation, which is skirted with PT ply slightly below grade. there is hardware cloth running down below grade, and wire lath stapled up to the plywood, with 30lb. felt behind that.
i'm wondering if you guys would be so kind as to walk me through the process of applying stucco.
also, what is the actual mix that i need? do i get the quickrete/sacrete mortar mix and use an additive to get me the stucco texture, or is there something ready to go out of the bag?
i understand there is an initial "scratch coat" followed by a final coat?
any tips and guidance at all at this point would be much appreciated.
thank you.
wombosi is offline   Reply With Quote
Old 07-17-2010, 11:21 AM   #2
Rewards Points: 5,336
Any Masonary supply should have bags ready to mix. You can buy coloring to add to the mix if you want.
Stuccoing has a descent learning curve involved. I'd practice on something before you go slapping this on the house.
Ron
Old 07-17-2010, 03:25 PM   #3
Registered User
Rewards Points: 526
http://books.google.com/books?id=0dz...age&q=&f=false
http://www.google.com/search?hl=en&t...=&oq=&gs_rfai=
Be safe, Gary
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
