1950s Style Wall Supports In Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 12:03 AM   #1
1950s style Wall Supports in garage
We are about to add drywall to our celling and walls in the garage. There are diagnol 2x4s that appear to be wall supports running in the 4 corners of the celling of our garage. The home was built in the early 60s. Can you advise is this truly wall supports, and if so, is there a better way to maintain the integrity of the structure without these?
clcho is offline   Reply With Quote
Old 04-09-2010, 01:17 AM   #2
jlhaslip's Avatar
Rewards Points: 2,098
they are wind bracing. The add some shear strength to the wall.
I would consider replacing them with let-in 1 x 4 bracing or let-in angles that sit flat to the wall surface to allow the board to mount flush to the stud faces.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
A Garage Steel Stud partition wall PaliBob Building & Construction 8 02-16-2009 03:32 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Carriage Style Garage Door tjeieio Carpentry 3 04-27-2008 05:58 PM
