1940-1950's Cold Store (under Porch) (///AG) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 11:04 PM   #1
SFX Group's Avatar
Send a message via MSN to SFX Group Send a message via Skype™ to SFX Group
1940-1950's cold store (under porch) (///AG)
Hi, so i have been pulled out the stud walls in the basement... then.. I find a door... never knew about this.
Turns out its a cellar under the porch, 6x6x6 feet, here is the problem, the walls all look fine, the roof looks to be 1 slab, HUGE crack alone a internal L shaped beam (its rusted, dropping concrete off it, top now cracking, it’s raining in the celler from the water coming in the crack that’s water logged the whole slab, its not a flow of water, rather the whole internal is just so damp it rains.
I notice this does not have a creathe hole (looks like the reason for the problem in the first place)
So it needs replacing... ideas?
Someone here said to get someone in, get a nice wood form made up inside the cellar, let them re-pour the whole top and make nice new stairs as well (about 12inch step that for some reason is 2inch then 10 it lift)...
Any views on this?
Is a cellar in a 1940-50's house common or was this guy ahead of his time (there’s seems alot in the house very advanced for its time, solid concrete pour base etc...).
While here, i need to get 4 quotes for a special sized outside door (30" wide, less than 67" tall), depending on any frames needed or air sills needed.... Thats the sized fitted at the moment but its a super old outside door (1inch think wood).
Many Thanks
Ashley
Copyright 2011 - www.ashleygriffin.ca
SFX Group is offline   Reply With Quote
Old 11-22-2010, 11:43 AM   #2
Rewards Points: 5,336
You would get price quotes from local installers, not here.
Take some pictures of this room.
Ron
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
Insulating Cold Storage below slab porch Chemist1961 Building & Construction 1 12-09-2009 09:20 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
