1930s House, Floor Joist Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 07:26 PM   #1
1930s house, floor joist question
hi, i am planning to gut renovate a 1930s house in ny. one of the (plaster) walls had an issue so we opened it up to take a look. in the process, we exposed some floor joists. i think they are 2x8, but what was strange was that a few looked bent. has anyone else seen this? pictures are attached...
thank you
1930s house, floor joist question-img_0584-1.jpg   1930s house, floor joist question-img_0588.jpg   1930s house, floor joist question-img_0589-3.jpg
s_ny10023 is offline   Reply With Quote
Old 03-11-2012, 07:35 PM   #2
Ironlight's Avatar
They are just warped. Most likely they warped in the first few years after the house was built...the first year even...as they dried out. Structurally they are fine. The only issue you may encounter, if any of them are warped enough, are some issues in drywalling the ceiling. Nothing that a little planing or furring would not address.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
jaydevries (03-11-2012)
Old 03-11-2012, 07:48 PM   #3
Rewards Points: 242
Yes, I have...not floor joists...but ceiling joists and rafters. High humidity and heat as best as I can figure. Your floor joists look just like some of my 1954 ceiling joists (2x12's...11.25" measured) and rafters (2x6's) over my master bathroom. I think mine was caused by heat and moisture.
But, could have been caused by drying process after they were installed as was said by Iron Light
Ed911 is offline   Reply With Quote
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
New House - Stairs Question tucker64 Remodeling 4 03-09-2010 08:47 AM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 12:23 PM
Whole house surge suppression question WoodworkerDave Electrical 4 10-02-2008 12:26 AM
Crazy question about full house construction. firemanpato Building & Construction 7 03-29-2008 05:32 AM
