18' Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2007, 08:16 AM   #1
18' Span
I have to span an opening of 18' and plan on using an LVL. I would like it exceed a 60 lb live load rating. Could anyone advise me as to what size lam will be needed.
jsp1948 is offline   Reply With Quote
Old 02-06-2007, 06:16 PM   #2
Construction Guru
I would recommend that you consult a salesrep for laminated beams, which are engineered for dead load more so than live load.
sheeter is offline   Reply With Quote
Old 02-06-2007, 08:56 PM   #3
remodeling pro
Get this specked from the manufacturer, it is not something for a "general rule of thumb". Your lumber yard can get the specific recommendation from the manufacturer who is supplying him. Also ask about the amount of deflection you will have on your span. If the beam is buried in a wall or ceiling it is usually not a problem, but if the bottom edge will be an outside corner with a drywall bead, the deflection will be noticeable when the bead is applied.
troubleseeker is offline   Reply With Quote
joist span? apowens Carpentry 17 05-04-2007 07:54 AM
Header Span Table cahardesty Building & Construction 1 01-22-2007 09:45 AM
conduit span 24" OC across trusses stagger19 Electrical 7 08-20-2006 07:20 PM
Beam Sizing Riddler Carpentry 14 08-05-2006 12:46 AM
rafter thrust/cathedral ceilings godin Carpentry 7 07-09-2006 06:44 PM
