18 Inch;x18 Inch Cement Patio Tiles - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 02:30 PM   #1
18 inch;x18 inch cement patio tiles
I'm laying cement patio slabs on top of my cement entryway . What kin of adhesive should I use , is mortar OK to use ?
Ida Hary is offline   Reply With Quote
Old 09-05-2011, 02:43 PM   #2
Thadius856's Avatar
Rewards Points: 504
I've hard of people laying them on "-1" of sand. And I've heard of people mortaring them in place.
I plan on ripping out my concrete and replacing it with a 4" crushed 3/4" rock bed, 1" of paver sand and then pavers. The patio comes flush to the laundry room floor, so I don't have a choice to build upward.
Thadius856 is offline   Reply With Quote
Old 09-05-2011, 03:14 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ida are you laying them tight to one-another or spacing them for a grout joint?
XXX
Old 09-05-2011, 03:26 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
18"x18"
There's that funky "malfunction" again!
XXX
Old 09-05-2011, 06:29 PM   #5
DIY staff
Rewards Points: 7,174
Isn't that the most irritating computer glitch???
Old 09-05-2011, 07:23 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Earlier I was trying to make it happen and I couldn't figure out at what point in the process it occurs. I am still wondering if proof-reading would catch it and one would have an opportunity to correct it.
XXX
Old 09-05-2011, 07:28 PM   #7
DIY staff
It's in the system----when CT changed over to the 'New and Improved' that showed up in my profile.which was done several years back.
It just happens on certain days----server error?
Old 09-06-2011, 08:55 AM   #8
cement stones on top of cement
I don't plan to leave any space between the stones
Old 09-06-2011, 01:23 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay good! If it were me I would use modified thinset mortar for ceramic tile and bond only the perimeter stones, allowing the interior stones to float. This will accommodate any freeze/thaw cycles that may occur and still keep everything in place.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Ida Hary (09-06-2011)
Old 09-06-2011, 05:28 PM   #10
Rewards Points: 4,454
bud's probably suggested the best method under the circumstances however be advised no tile ( conc, ceramic, glass, etc ) is permanent for exterior use.
Old 09-06-2011, 05:51 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm laying cement patio slabs on.....
What exactly are you using? Describe these "cement patio slabs".
XXX
Old 09-06-2011, 09:02 PM   #12
mossypath's Avatar
You can adhere your pavers directly to the concrete using paver adhesive from your local distributor.
mossypath is offline   Reply With Quote
The Following User Says Thank You to mossypath For This Useful Post:
Ida Hary (09-11-2011)
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
New cememt patio stained by wet leaves Bhoward Landscaping & Lawn Care 7 12-03-2008 12:35 PM
Replace rotted 2x4's in cement patio KennS Building & Construction 3 06-19-2008 12:41 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
