18' Diam. Gazebo Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 08:43 AM   #1
18' diam. Gazebo questions
In my backyard there is a large concrete slap in a quasi triangle design. In the center is an 18ft diameter dirt patch that the previous owner used to use to place an outdoor pool. I would like to build a gazebo on this dirt patch.
I like my neighbors to the Southwest and the gazebo would block their view to mountains at the Northeast, so I was thinking of sinking the dirt patch down 1.5ft and building the gazebo with a low pitch. About 15deg pitch.
I've contacted the city about building codes and I don't need any engineer sign-off. They only need a design of the roof materials and how I plan to anchor the gazebo.
My plan is a hexagonal design to fit into the circle with half-rafters used for the roof. The posts would be ~9ft apart and the roof pitch would be about 15deg. 9ft span, 2.5 ft rise. Is this pitch ok if I use half rafters? Do I need posts larger than 4"x4" treated lumber? Would I need to half joists spanning all the way across the diameter of the roof, or are the rafters enough?
The roof will be wooden rafters, 3/4" plywood and spanish tiles ontop. I plan on hanging maybe some lights and an exterior fan.
I live in Albuquerque, NM. Rainfall is minimal, but winds can be rough. We can get 70mph gusts on occasion in March-May.
I plan to anchor the posts into the ground with sunken concrete posts much like a deck.
Magno is offline   Reply With Quote
Old 01-13-2012, 10:17 AM   #2
Old School
Willie T's Avatar
I'm feeling dumb. What's a "half-rafter"?
Willie T
Old 01-13-2012, 10:53 AM   #3
Scope this weblink. The topview of the gazebo shows a half rafter layout for the roof.
http://www.blocklayer.com/gazebo.aspx
Old 01-13-2012, 11:14 AM   #4
Old School
Willie T's Avatar
If you say so.....
I saw a pergola type roof. Is that what you mean?
But I can't see how that would help your neighbor's view of the mountains.
Willie T
Old 01-13-2012, 11:28 AM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
A gazebo can look dumb with too low of a pitch.
And you do need ceiling joists to hold it together.
Sent from a Samsung Galaxy SII
titanoman is offline   Reply With Quote
Old 01-13-2012, 12:55 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Some members here can design this for you but not for free.
Andy.
AndyGump is offline   Reply With Quote
Old 01-13-2012, 01:28 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 774
First I heard of half rafters also.
If you want to make it lower make it a step or two down.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-13-2012, 01:42 PM   #8
Disabled wood vet
titanoman's Avatar
Half-rafters are just rafters that go to a head-out so you don't have to cut those rafters at ridiculous compounds and then try to nail that cluster**** of rafters coming together at the peak.
And the head-outs almost kind of serve as collar ties, but I would still have joists in it.
(One octagon gazebo I built I hung a 300 Lb church bell from the peak).
Old 01-13-2012, 01:57 PM   #9
Rewards Points: 2,212
From your description it sounds like you want to sink the floor down. There could be water issues with this.
mae-ling is offline   Reply With Quote
Old 01-13-2012, 05:14 PM   #10
I am already planning on sinking the gazebo down 1.5 feet, for asthetic reasons also. The backyard is excavated 4-5 feet above ground and the yard plot where the gazebo would be is next to an arroyo and the service road, so a simple channel off the side will drain easily into the arroyo. I'm not worried about the water.
I could sink it lower, but then I'd have to tear out concrete and make additional steps down so that tall people (i.e. me) don't smack our heads every time we go down to it.
Old 01-13-2012, 08:47 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 774
Good point.
Jim
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Build a Gazebo off my Deck with a walkway from the deck to the gazebo WMarkel Building & Construction 2 11-18-2011 03:56 PM
possible gazebo off my existing deck rollinastang Carpentry 3 05-23-2011 03:52 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 12:59 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
