16' Support Beam ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 01:57 PM   #1
Question
16' support beam ?
I am looking to remove half my load bearing interior wall on my main floor to open up my kitchen. I was wondering if three 2"x10"by 16' would be enough support for that size opening. It is a 2 storey home.
Thanks,
JamesF is offline   Reply With Quote
Old 01-05-2011, 02:08 PM   #2
You need to have the beam sized for the load
You can't guess at this
For a 13' 6" opening I needed either (3) 12" LVL's or (2) 14" LVL's
The (2) 14's were less $$ & stronger
The lumber yard (not big box) sized the beams & they would have sent the plans out for an engineer stamp if I needed one
Old 01-05-2011, 04:23 PM   #3
cocobolo's Avatar
Rewards Points: 6,098
Thanks,
James, the safest thing for you to do would be to talk with your local building inspector. You will be requiring a permit for this work anyway, and since they will be the people approving your permit, it is best to make sure they are happy.
3 2 x 10's falls somewhat short for that span. If you pick up a copy of the CHMC building specs, you will find the information in there. Your local office may have a copy for sale, or I believe you can order one online directly.
If you plan on doing more work of this nature, it is well worth having.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
The Following User Says Thank You to cocobolo For This Useful Post:
JamesF (01-06-2011)
Old 01-05-2011, 05:41 PM   #4
WaldenL's Avatar
Rewards Points: 268
James, don't forget to look down too. You're looking for a 16' opening (well, a bit less than 16'), but what's under those end points? Are you on top of a window in the basement for instance? Your 16' may be 18 or 19 by the time you find solid ground.
WaldenL is offline   Reply With Quote
The Following User Says Thank You to WaldenL For This Useful Post:
JamesF (01-06-2011)
Old 01-05-2011, 07:20 PM   #5
Carpenter
dtsman's Avatar
Look into engineered wood beams. http://bct.eco.umass.edu/publication...s-and-headers/
Not sure if the site link is worth anything to you but may point you in the right direction for your search for info.
Also, steel is always an option.
I did a patio enclosure with 3 sets of sliding glass doors all together and we had to use something like a 22' beam. We used a steel I-beam. We used lots of liquid nail to put 2x2 cripples into the openings of the beam to screw drywall too.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
The Following User Says Thank You to dtsman For This Useful Post:
JamesF (01-06-2011)
Old 01-05-2011, 07:27 PM   #6
Some permit offices will help you
But most will tell you to hire en engineer to have the load calc'd
If they assist you & tell you what to do they are then liable if something goes wrong
They are there in most cases to inspect the work, not tell you how to build it
I did have to add support down to the foundation in the basement for the beam support
In my case it was less then 12"
The Following User Says Thank You to Scuba_Dave For This Useful Post:
JamesF (01-06-2011)
Old 01-06-2011, 08:56 AM   #7
Talking
Thanks,
Thanks guys. Sounds like great advise. We are just in the planning stage of options for our kitchen reno. We were going to replace the ceramic tile floor with hardwood, but we thought while we are doing that we may want to take the time to remodel. Armed with this info I think I may just put new flooring down. If this was a home that we were thinking about staying in I would consider a complete reno, but seeing we will be downsizing in 2 or 3 years it seems like a large undertaking at this point. Think I will go break the news to my wife.
Thanks again for your input.
For the record I am going to blame you guys for her not getting a window seat in the kitchen now, sorry, lol.
James
Support I beam needed ThisOldH0use Building & Construction 28 05-16-2012 09:10 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 10:14 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 05:55 AM
