Old 11-11-2007, 07:18 PM   #1
16" OC wall framing
Hi all,
If i layout my studs on 16" OC from my outside wall then all my studs are on 16" on center. Ok, Cool!
Now, when i nail my sheathing on the exterior it all hits perfectly in the middle of each 2x4.
Here is my confusion.
I built my corners and set them in and now notice that if i measure from the inside corner to the first stud i am no longer on 16" centers.
For my exterior sheathing i am ok; however, for my Sheetrock i am not on 16" centers any longer.
What am i missing here?
thanks for any help!
Texas
erikkl2000 is offline   Reply With Quote
Old 11-11-2007, 07:31 PM   #2
16" OC wall framing
Cut the first sheet of sheetrock you put up. The rest will be ok.
spebby is offline   Reply With Quote
Old 11-11-2007, 07:33 PM   #3
General Contractor
joasis's Avatar
16" OC wall framing
You must cut one or the other...and since drywall is easier to work, guess which one gets picked?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 11-11-2007, 07:37 PM   #4
Custom Cabinet Maker
16" OC wall framing
3/4" of an inch :}:}:}:} on the outside, your first layout mark at 16 oc is 15 1/4 from outside corner then 16's.Did you remember to put a nailer in the corner? Also you have to run from the last stud closest to 8' back to corner and cut to fit unless you can run full sheets corner to corner
skymaster is offline   Reply With Quote
Old 11-11-2007, 10:07 PM   #5
16" OC wall framing
Yes that is exactly how i did my wall layout. I pulled from the outside wall to 15 1/4 then 16's from their.
For my interior wall i have corners built. This is when the confusion set in, because the oc was correct on my exterior side but now looked off on the interior side.
Thanks to you guys i have it figured out now!
Thank you very much!
Texas
Old 11-11-2007, 10:12 PM   #6
16" OC wall framing
You can see the corner that i am talking about here.
http://7805newcastlect.afccinc.com/view/view.shtml
This was my first wall so do not beat me up about the headers, trimmers, cripples; because i already know this, and tomorrow we are full force with the correct understanding.
We just wanted to start and step back for a bit to let what just happened soak in.
You can also find info here
http://RealTimeBuilding.Com
Old 11-11-2007, 10:21 PM   #7
16" OC wall framing
Erik; NOW I know exactly what the problems are;
First look from the OUTSIDE in and it will look alot better
Second you are from Texas
ROFLMAO
Sorry could not resist. The Devil made me do it
Jack
Old 11-11-2007, 11:03 PM   #8
16" OC wall framing
It was from the inside out that threw me. The other wall is not effected by this because its plated butt against the other wall.
I have got it now and i am pumped up about tomorrow!
Thats ok; you can poke at me about Texas, i have lived all over so for now it is Texas.
Old 11-12-2007, 12:30 PM   #9
16" OC wall framing
Many ,many,many years ago in a galaxy far far away. I dwelled with Aliens in a place called Lackland Air Force base in some thing called San Antonio
LOL
Old 11-13-2007, 09:34 AM   #10
16" OC wall framing
Im back for more.
We are having to rough in an area for triple unit window. This unit is set in a frame the overhangs the slab by , what i think to be, is 8".
It is the window with the copper above it, second from the right.
http://afccinc.com/Help/customHome.jpg
Floor Plan:
http://afccinc.com/Help/windowHelp.jpg
You can tell by looking at the floor plan that this window is not on the slab.
Anyone can scratch something together are send a link that would be great. I will check my email on the job in a little while.
Texas
Old 11-16-2007, 10:29 PM   #11
remodeling pro
16" OC wall framing
You are not "missing" anything. As you have observed, you can't measure from the outside corner of the wall to establish 16" centers for the sheathing, and from the inside corners to establish 16" spacing for the drywall at the same time. Since the framers are there first , they are obviously going to layout to make their wall sheathing as easy as possible for themselves, so the sheetrockers will have to cut the first sheets on most exterior walls; besides sheetrock material waste is cheaper than plywood material waste. The interior walls should lay out well for the sheetrock.
troubleseeker is offline   Reply With Quote
Old 11-16-2007, 11:46 PM   #12
16" OC wall framing
Erik; I understand what you are saying however what is the question? :}
With only 8" projection the unit should be self supporting. If an Andersen unit it will contain interior cables that you adjust for level and support before you close interior with trim. If this is your question.
Jack
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Framing a Wall with a Soffit on Top sethr Building & Construction 2 05-21-2007 09:14 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Framing an angled wall TheBrownsFan Building & Construction 8 01-14-2007 10:22 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
