16' Joist Span Question. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 06:17 PM   #1
Rewards Points: 150
16' joist span question.
If running 2x8 joist 16' and beams spanning about 4' and beams about 7' apart and a 2' cantilever. Rim joist and hangers at end. Where the joist crosses atop beams is toenailing sufficient or would you use like a hurricane strap to tie together? Is there much loss in structural integrity by running the joists in between beams using hangers at both connections to beams?
MikeVila is offline   Reply With Quote
Old 05-03-2012, 06:42 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
it depends on what is on the end of the cantilever. weight put on the end of a cantilever wants to create uplift on the back span of the joist and reverse deflection of the joist. that's why the 2009 International Residential Code Section R502.3.3 states that "floor cantilever spans shall not exceed the nominal depth of the wood floor joist. Floor cantilevers constructed in accordance with Table R502.3.3(1) shall be permitted when supporting a light-framed bearing wall and roof only."
here is a link for the 2009 IRC http://publicecodes.citation.com/icod/irc/index.htm
check with your building official and find out what the provisions of your state building code require.
sure that's not the answer you were looking for but is the best course of action I can suggest
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
mae-ling (05-03-2012)
Old 05-03-2012, 09:45 PM   #3
Rewards Points: 150
Yeah I'm more concerned about the joists on top of beams compared to in between beams. Is it a matter of preference and job? Just a deck for above ground pool.
Tried getting in contact about codes but never get anywhere. We're just going to do piers and beams and make sure everything is beyond minimum spans, etc.
Old 05-04-2012, 01:15 PM   #4
Rewards Points: 150
Anyone else have input on joists resting on beams as opposed to in between beams? Thank you.
Mile
Old 05-04-2012, 03:13 PM   #5
Civil Engineer
Rewards Points: 4,792
Where I live it is permissible to place the joist over the beam or between the beams. If placed between the beams, generally a Simpson hanger is used on each end. If placed over the beam, the joist may be toenailed or may be attached to the beam using a hurricane clip. See Figure 6 of the 2006 International Residential Code for deck construction for diagrams. Your code may be different.
Old 05-04-2012, 07:12 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
If possible I like to have use drop beams (under the joists) instead of flush beams (flush to top and bottoms of joists).
The reason differs per job but as rule of thumb I like drop beams more.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 05-05-2012, 12:07 AM   #7
Registered User
Rewards Points: 5,522
Here is the Deck Code that Daniel said: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Notice Fig. 1B and the commentary about flush beams not allowed on pp. 23 "Joists", and around "hangers" near fig. 6 (as per Daniel). The span tables are for beams/joists listed are for termination of joists, not where joists are on both sides of a beam. You need to check locally for spans then.
Gary
Gary in WA is online now   Reply With Quote
Old 05-05-2012, 07:09 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
toenailing joists down to a drooped beam is allowable if the deck is attached to the house at the other end of the joist. if it is a freestanding deck hurricane straps are required,at both beams. there is no difference structurally if you set joists onto a dropped beam or if you use correct size joist hangers and hang every joist between the beams.
hand drive is offline   Reply With Quote
Old 05-05-2012, 08:50 AM   #9
Civil Engineer
Hand drive, I agree there should be no difference structurally between a joist nailed or strapped to the top of the beam versus the joist flush attached to the beam using hangers. However, page 7 of the 2006 IRC code does NOT agree. Specifically, it states "joists shall not be attached to opposite sides of the same beam". I assume this is to minimize the chance of compromising beam strength by nails striking each other from opposite sides, so I suppose it would be OK if you offset the joists, but this is not very clear. Not always easy to understand the intent of code.
Old 05-06-2012, 08:40 AM   #10
AHH, SPANS!!!
Before I mentioned putting the joists on with hangers between the beams, what I meant was putting the joists in with joist hangers with a ledger attached at the house and a perimeter beam for the rest of the deck. of course this depends on which way ( in accordance with the house) the decking goes down on the deck. the joists could go parallel with the house with joist hangers nailed to double beams down the sides of the deck.
about attaching joists with hangers to both sides of a beam, I have done multiple decks with multiple girder beams breaking up the joist spans and we always did our hangers on both sides of the beam to hold up the joists. the girders are usually triple or quad beams built with the same size lumber as the joists and not just a double beam assembly. never had issues with inspections passing.
Girder span question........ aaronn Building & Construction 2 09-01-2011 10:35 AM
Steel Ceiling joist ttilton Building & Construction 1 08-26-2010 08:26 PM
Max span length on 4-2x10 fir beam? gadget463 Building & Construction 4 08-03-2009 05:51 PM
Maximum span without intermediate support question yaryar Building & Construction 2 11-11-2008 10:08 PM
joist span? apowens Carpentry 17 05-04-2007 07:54 AM
