140x50 A Good Sized Lot ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 10:14 AM   #1
140x50 a good sized lot ?
140x50 a good sized lot? I am thinking of buying this lot to build a house on over the next 3 years. All services are there on the lot already and it's flat land...
jayinwww is offline   Reply With Quote
Old 04-29-2009, 10:17 AM   #2
weekend warrior
Hobb3s's Avatar
Depends where you live, but if you're in a decent sized city, that's a good lot size. Most new homes are built on lots 50x60, at least in my city, or if you have a town home 30x60.
Hobb3s is offline   Reply With Quote
Old 04-29-2009, 10:23 AM   #3
Rewards Points: 1,016
50x100 was a common size lot when I lived in suburbs of New Orleans a few years ago. I had a 50x135 lot with a 1850 sq ft house on it. It was well set back from the street and had a decent back yard.
The narrowness will limit your choices in design - the house will be narrow and deep. This results in having a front perspective with a large percentage visially occupied by the garage door(s).
Old 04-29-2009, 11:57 AM   #4
Many new spec homes in Seattle are being built on lots that are 30' wide. This is not a typo.
Mop in Hand is offline   Reply With Quote
Old 04-29-2009, 01:05 PM   #5
Rewards Points: 150
Some codes require 10ft. from the lot lines to build, so that effectively reduces your lot to 120x30. Depending on how the lot lays it may put you within 20ft of a neighbors house! That's not for me!
Gary
Gary_602z is offline   Reply With Quote
Old 04-29-2009, 01:52 PM   #6
weekend warrior
Hobb3s's Avatar
Gary
I thought it was 10 ft easement, but 5 on each persons lot. So you're Ten feet apart total.
Old 04-29-2009, 01:56 PM   #7
30 feet wide - that barely leaves enough room for a hallway!
To the OP - as you can see from the replies, your prospective lot size is not uncommon for a city or surburban lot and building a house on it should be very doable.
I have lived in a dormatory room, military barracks, condo, small lot with close neighbores, large 1/2 acre lot, etc. Each has it's pros and cons when it comes to livability, upkeep, etc.
It depends on what you want.
Old 04-29-2009, 11:02 PM   #8
Here its nothing within 15' of the property line for each house
So 30' seperation
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Recommendations for a good corded and/or cordless drill jimmyfloyd Tools 15 11-30-2008 12:20 PM
How can I tell if my taping is good enough? yummy mummy Building & Construction 4 10-01-2008 10:16 AM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 09:16 PM
