12x12 Screened Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 11:32 AM   #1
12x12 screened porch
Is 14,4441 a reasonable cost to build a screened 12x12 porch in harnett county, nc?
btm1945 is offline   Reply With Quote
Old 06-18-2012, 11:48 AM   #2
DIY staff
Rewards Points: 7,174
How many bids do you have in hand?
Asking a few local builders is the only way to get an idea of price---
That $14.000 sound like a lot from here for a 12x 12 screen porch---But I have not seen the plans--or the site ,nor do I know your local permit costs.
btm1945 (06-18-2012)
Old 06-18-2012, 07:07 PM   #3
Thank you Mike. The permits are around $40 to $60 each. The porch will have a base of brick, a cement floor and will be set on my patio which is cement.
Old 06-18-2012, 08:20 PM   #4
DIY staff
You still need to get several local bids---With concrete,brick and the wood structure above--that $14,000 price might not be that far off.
Now I am going to try to merge your threads together---Mike---
Old 06-18-2012, 09:44 PM   #5
12x12 porch
Thanks, I am waiting on another bid, and will set up another.
Old 06-19-2012, 08:55 AM   #6
DIY-er
There are many online screened porch kits you can buy. You could check the price of these, factor in what the labour would be, as well as the cost of the brick foundation to give you an idea. Many of the porch kits are DIY. You could probably hire someone to do the concrete floor and foundation, then install the screened porch and roof yourself, may save a pile of money.
I have seen a screened in pergola go for as much as $25,000 where I live, so depending on your design, it may not be far off. However, construction costs vary greatly depending on which part of the country you are from. The American coasts have the most expensive construction costs which decrease as you move into the interior. Some online cost calculators take this into account.
KevinPh is offline   Reply With Quote
Old 06-19-2012, 06:55 PM   #7
Thanks for the info, Kevin, I will check it out.
Replacing Deck Boards on Screened in Porch kendoit Building & Construction 12 01-24-2017 01:34 PM
Need Help - Installing Hot Tub on Elevated Screened Porch Floor!!! rpr Building & Construction 12 09-20-2011 02:54 PM
need some fresh ideas for finishing screened porch joetab24 Carpentry 5 01-07-2011 05:32 PM
Free-Standing Deck with Screened Porch Tied into existing Roof butlerbach Carpentry 2 05-14-2009 07:25 AM
What can we do with this screened porch? pcampbell Carpentry 6 07-22-2008 06:59 AM
