12 Foot Roof Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 11:12 AM   #1
12 foot roof span
I am installing a metal roof. Will a 2 x 8 rafter hold with out saggi9ng
BertLowry is offline   Reply With Quote
Old 02-17-2012, 11:34 AM   #2
concretemasonry's Avatar
Rewards Points: 2,594
Probably not if you are in a heavy snow area. What spacing?
That is why the site registration asks for a location to get more accurate answers to your questions.
Dick
concretemasonry is online now   Reply With Quote
Old 02-17-2012, 09:43 PM   #3
Rewards Points: 944
One rafter every 4' OC should handle most situations.
You can always add more down the road as the situation warrants.
Green construction is the way to go.
cleveman is offline   Reply With Quote
Old 02-17-2012, 09:53 PM   #4
Without knowing the roofing system, is that called a "patch job"? Iowa does get some heavy wet snows especially for joists on an unknown slope.
Dick
Old 02-18-2012, 09:31 AM   #5
Rewards Points: 944
I would of recommended 8' span if I thought that would give something to put the sheathing on.
Did you not see the icon ?
In fact, 2x6's are generally used 24" OC to span 12' on garages. We'll see what he ends up with. When I have looked into metal roofs for residential apps (never done), it is always recommended to just put them on a normal sheathed roof, which I thought would defeat the purpose of the low cost metal.
He'll end up with some purlins.
Probably not many pole barn builders on the diy site.
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Maximum Beam Span to support a Shed Roof? rk-nc Carpentry 6 10-12-2010 08:35 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
