Old 04-27-2011, 07:59 AM   #1
bsa_bob
Question
10x12" shed has to be lifted! how--????
My shed is all wood, above the ground, It needs to be lifted up. Do to sinking over the years i need about 8". I have three rollaround floor jacks. 3-ton capacity.I will install some more blocks, which i have here.
I have never done this before, and could use some info, or tips if you have any. thanks for looking bob s
bsa_bob is offline   Reply With Quote
Old 04-27-2011, 08:18 AM   #2
old guy contractor
tcleve4911's Avatar
1st project....empty the shed to get all the weight you can out of it.
tcleve4911 is offline   Reply With Quote
Old 04-27-2011, 08:20 AM   #3
old guy contractor
tcleve4911's Avatar
Are you planning to lift the entire building all at once and then lower it down onto the new blocks?
....or just a corner at a time?
Old 04-27-2011, 08:31 AM   #4
Moderator
kwikfishron's Avatar
A Shovel, Block and Lever.
Pictures of your situation would help.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 04-27-2011, 08:42 AM   #5
old guy contractor
tcleve4911's Avatar
Get some help!!!
Old 04-27-2011, 08:47 AM   #6
old guy contractor
tcleve4911's Avatar
Dig a hole for your jack to get into.
Use scraps between your jack and the wood on your shed.
Never jack directly onto any finished product.
Have plenty of scarps or extra blocks to act as temporary supports so you're not always relying on just the jack.
Old 04-27-2011, 08:48 AM   #7
nap
You talking to me?
nap's Avatar
Archimedes said "Give me a lever long enough and a fulcrum on which to place it, and I shall move the world."
Old 04-28-2011, 01:41 PM   #8
bsa_bob
The pictures i take will look just like this.My wondering mind, was how do you do it, as to lift one whole side, get her where i want her.then do the back or front or other side next??????????????? leveling as i go.Any comments are welcomed bob s the old guy plumber
Old 04-28-2011, 02:01 PM   #9
nap
You talking to me?
nap's Avatar
a little on one side, then a little on the other. Back and forth.
If you lift too far on one side, you will impart a lot of stress as the building leans.
depending on how this thing is built, you might want to put some bracing inside. If nothing else, running angled braces on each wall to help prevent racking of the walls.
Old 04-28-2011, 03:22 PM   #10
Tizzer's Avatar
I'd do a corner at a time, at one half increments. Jack 1 corner 4", use a brick or 4" cinder block, whatever. Repeat on all corners.
The next time around with the jack will be your 8".
Tizzer is offline   Reply With Quote
Old 04-28-2011, 03:41 PM   #11
bsa_bob
I just remembered i have a block in the center maybe two. How in the devil am i to place, lift pieces[blocks] in the middle. under the floor. Now that i have help i'
m going to start this project this next week for sure.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 12:35 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
