10x10 Free Standing Deck - Building & Construction - Page 4 - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 11:14 PM   #46
Rewards Points: 13,450
Read the sticker on the ends of any 2 X.
There not direct ground contact rated.
Only 4 X 4's, 4 X 6's, 6 X 6's are.
I would go with 4, joist for that ramp, not 3.
Old 10-10-2013, 08:50 PM   #47
Rewards Points: 590
I plan to use those flat solid concrete blocks under the stringers. I will level out an area with them. That or I'll use the extra bag of concrete I have and make a little platform.
nikeman is offline   Reply With Quote
Old 10-16-2013, 11:01 AM   #48
Rewards Points: 590
The framing is done and I'm ready to put down the decking. I have tons of 2.5" Bulls Eye premium decking screws with a star head and brownish coating. Do I need to predrill every hole before I put the screws in? 16 screws per board and 22 boards makes a lot of predrilling.
Old 10-16-2013, 11:08 AM   #49
cortell's Avatar
Rewards Points: 504
I pre-drill only at the board ends, since the wood is much more likely to split there. I'm assuming you're using wood decking and not composite. Stay at least 3/4" from the board edges, but not much further.
cortell is offline   Reply With Quote
Old 10-17-2013, 07:29 PM   #50
Rewards Points: 590
Here's what I ended up with minus the ramp. I found out that I was not nearly as square as I thought I was after putting down the first 2 decking boards. I was keeping one side even but since it wasn't square the boards went from 1/2" overhang to over an inch within 3 boards. Lol. I just gapped a little on that side to make it look better. I also found out that I suck with a circular saw.
The Following User Says Thank You to nikeman For This Useful Post:
cortell (10-17-2013)
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
20x30 Free Standing Carport Build Questions ratherb-buggin Carpentry 2 08-21-2011 10:45 AM
Free standing block wall foundation 3DPiper Building & Construction 4 10-19-2006 08:42 PM
Wholesale IPE or Cedar Decking free deck design woodybill Carpentry 1 01-28-2004 11:57 PM
