Are 10d Twist Nails OK For Interior Wall Framing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 01:01 PM   #1
the Musigician
DangerMouse's Avatar
Are 10d twist nails OK for interior wall framing?
Yes? No? Just curious, they would be better in my case.
DM
Old 05-14-2010, 10:41 AM   #2
Rewards Points: 3,130
Framing generally requires 16d sinkers, not the "twist" nails. Those actually tend to back out over time.
Old 05-14-2010, 10:52 AM   #3
the Musigician
Thanks.... is there code on this anywhere?
DM
Old 05-14-2010, 12:15 PM   #4
Civil Engineer
Rewards Points: 4,760
Massachusetts building code has a set of tables specifying minimum nail size and spacing for framing in the appendix. Your local building code may have a similar table.
Old 05-14-2010, 08:34 PM   #5
Registered User
Rewards Points: 5,514
http://www.mcvicker.com/resguide/page014.htm
Be safe, Gary
Old 05-15-2010, 04:15 PM   #6
Code or no code, they'd actually work as far as nailing plates to studs or plates to plates. 10d are 3", 16d are 3 1/2". Two plates together are 3" and when nailing a plate to a stud, 1 1/2" would penetrate the stud as opposed to 2" with a 16d nail. All you need is enough to hold the stud in place and stop it twisting. I never use twist nails. If I have a need to use them, I use screws.
Having said all that, I'd still use 16d sinkers for general framing.
mrgins is offline   Reply With Quote
Can I use ring shank nails for framing? bluefitness Building & Construction 3 12-18-2008 09:17 PM
Size/Type of Nails for Interior Framing? mfleming Building & Construction 2 09-16-2008 08:39 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
