-   -   Are 10d twist nails OK for interior wall framing? (http://www.diychatroom.com/f19/10d-twist-nails-ok-interior-wall-framing-71146/)
DangerMouse 05-13-2010 02:01 PM
Yes? No? Just curious, they would be better in my case.
DM
md2lgyk 05-14-2010 11:41 AM
Framing generally requires 16d sinkers, not the "twist" nails. Those actually tend to back out over time.
DangerMouse 05-14-2010 11:52 AM
Thanks.... is there code on this anywhere?
DM
Daniel Holzman 05-14-2010 01:15 PM
Massachusetts building code has a set of tables specifying minimum nail size and spacing for framing in the appendix. Your local building code may have a similar table.
Gary in WA 05-14-2010 09:34 PM
http://www.mcvicker.com/resguide/page014.htm
Be safe, Gary
mrgins 05-15-2010 05:15 PM
Code or no code, they'd actually work as far as nailing plates to studs or plates to plates. 10d are 3", 16d are 3 1/2". Two plates together are 3" and when nailing a plate to a stud, 1 1/2" would penetrate the stud as opposed to 2" with a 16d nail. All you need is enough to hold the stud in place and stop it twisting. I never use twist nails. If I have a need to use them, I use screws.
Having said all that, I'd still use 16d sinkers for general framing.
