Old 06-02-2006, 12:22 AM   #1
10-12' wide patio door installed
I'm going to be installing a patio door between 10-12ft wide, which will knock out quite a few studs. The wall supports a second story above. Since this is in a basement with a low ceiling, I'd like to have the narrowest header that would be sufficient to support that size of a door opening. Ideally, it would be no more than 6", and preferably closer to 4". I'd be willing to use steel I-Beams if it were possible to, but if I have to use wood for the header, what would be recommended? Also, if steel I Beam recommended for header, how can I attach the I Beam header to the supporting studs? Any suggestions much appreciated.
gregoryedgar is offline   Reply With Quote
Old 06-02-2006, 07:52 AM   #2
General Contractor
joasis's Avatar
You can pick up advice here, but you really need to have a first hand look from a qualified contractor or inspector. You will not get a 4 inch steel I-beam to carry that load you propose, but maybe a 6...maybe. Lots of factors will be in play, such as the load above being in a gable end, sidewall, or if any of the load is carried by other factors.
joasis is offline   Reply With Quote
Old 06-02-2006, 07:57 AM   #3
Master Craftsman
Big Dave's Avatar
I agree with joasis but one posibility is to replace the rim joist with a header then joist hanger the joist off of that. It will be alot of work and you will have to support the load above temporarily while it is being installed.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 02:30 PM
Covered Patio Cost? RBPD5015 Building & Construction 2 04-23-2006 12:32 PM
